Whos running PVC softop? - Defender Source
Old August 6th, 2013, 10:08 PM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
Question about the header bar and seal.
Seems that the bolt holes line up, but my gutter pieces are slightly in the way of the header bar sitting where it should (maybe 1/4-1/2 inch too far forward).
Looks like notching the trailing edge of the header bar a bit would fix the prob. Curious if I'm missing something.
Also, is there a gasket/seal that should go between the top of the windscreen and the header bar? Bead of silicon? Thx
Old August 7th, 2013, 05:11 PM
josh-man's Avatar
josh-man
joshua
Bumpity
Old August 7th, 2013, 06:29 PM
sro
Sam Odio
2008 LR2
There was a rubber seal that came with my header bar. I imagine some silicone would do fine though.
Old August 7th, 2013, 09:30 PM
josh-man's Avatar
josh-man
joshua
Thanks. Did it require notching the header bar?
Old August 8th, 2013, 12:30 AM
sro
Sam Odio
2008 LR2
I did not need to cut the header bar in any way (though I have a ROW bar). I've never heard of anyone having to do that. I don't have a gutter kit, though.
Old August 8th, 2013, 05:28 AM
maleger
Marc-Andre Leger
I use a whole tube of sillicon to get a good seal (and avoid getting water to spill on driver and passenger when it rains). However, using too much sillicon makes the header bar hard to remove if you need to reinstall the hardtop in the winter, like me. I find that the seal & peel type of winterizing sillicon works best, but it will only last a season 4 to 6 months at best under actual driving conditions.
Old August 8th, 2013, 11:18 AM
josh-man's Avatar
josh-man
joshua
Ahhhh thanks. Ok I only have a soft top. Hugely helpful
Old August 8th, 2013, 03:38 PM
Naplm00
Matthew
I just use foam stick on tape.usualy used to seal air conditoioners in windows to put my header bar on.
No notching required
One side OEM running board off 94 Softop Happyxhour For Sale - Parts 1 April 27th, 2011 02:43 AM
Running Rich Please Help bstraw Defender Technical Discussions 23 October 26th, 2007 10:44 AM
Dash, Running & Head light PROBLEM ! Weldon Defender Technical Discussions 5 November 9th, 2005 02:04 PM
It's Running! Mike Hippert Misc. Chit-Chat 26 June 2nd, 2005 08:04 AM
DS Running light? Eric Siepmann Defender Technical Discussions 1 June 27th, 2004 07:55 PM
