Who sells galvanized D90 sliders - Page 2 - Defender Source
Old March 18th, 2011, 09:45 AM
dchapman
Daniel Chapman
1999 D1
$150 for prep, galvi, and powder???? That's cheap as shit if so. Tami had the shitty Rovertym powder coating sandblasted off her LR3 bumper ($80.00), and the powder finish (thermoset) was $400.00.
Old March 18th, 2011, 10:10 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Yep, I stripped them first but they do the whole chemical dip, hot dip, and PC for that.
Old March 18th, 2011, 02:41 PM
TS888's Avatar
TS888
Tony Sims
1984 110
My sliders are painted. I figure I can afford a lot of rattle cans for the price of galvanising, and powder coating sliders is just dumb unless you only drive to the mall.
Tony
1984 110 "Smokey" (sold)
Old March 18th, 2011, 03:06 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
As usual everything is more complicated in Daniels world.
Yes there are minimum sharges.....it is actually closer to $350 around here (500lb). I do large batches that generally run 2k or more. If I don't have enough (rare) it's not usually that hard to split it with someone.
Vent holes are not just for expansion. If you dont have them some parts will actually float. You also need to place the holes so that they will let the zinc in AND back out or you end up with a steel coated zinc ingot.
New work only requires very minimal venting (1/4" holes.)
Old work that may have rust inside will require large holes to allow the acid bath to remove all the junk.
A good shop understands this and I have yet to have these staining issues you mention. I have work in the shop now that has been driven in the NE winters for a decade and has yet to bleed.
The only unusual prep my PC shop does is warm water wash and rub down with scotchbright. You can hardly break the surface with a hammer, and in general I'd have to say it is better than going over bare steel.
Matt Browne
Old March 18th, 2011, 03:25 PM
DonFromWhitby
Don Andrews
'94 NAS D90 #CDN-80, 2011 LR4
Originally Posted by evilfij View Post
I can't seem to find any and I don't want black.
I bought a nice set from the UK from FirstFour offroad... a black set with tree sliders that double as steps... they also sell the galv ones.
Tools me about 15m to install em... I documented it in this link:
http://www.landroveradventure.com/in...ades&Itemid=58
Old March 20th, 2011, 09:00 AM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
You want galvanized and then sprayed with bedliner for sliders, in between use a Zinc chromate primer to get adhesion to the zinc and then an adhesion promoter to get the bedliner to stick really well. Works great, I do this when I re-galvanize inner fenders and bumpers and it lasts way better than anything else.
90, d90, slide
Multiple D90 Parts discojosh2000 For Sale - Parts 13 November 2nd, 2010 07:35 PM
Rockware sliders and rear shock mounts for D90 Shane@EVS For Sale - Parts 4 March 23rd, 2006 12:45 AM
I've Got A 97 D90 Frame That was just Galvanized ksteven Defender Technical Discussions 21 March 24th, 2005 11:22 AM
Want to Buy: D90 Galvanized Frame Steve Friedman Wanted 0 August 27th, 2004 12:28 AM
» Defender Registry
Cash
gilby
Landy
x-pat
Add your Defender
