Who is a clutch push rod expert? - Defender Source
Old January 10th, 2013, 06:21 AM
OK how do you get the little plastic clip that holds it on the arm in place?
Old January 10th, 2013, 10:54 AM
This clip. I can't poke in there enough to get it in the slot on the arm. If anyone has a trick, I'm very interested to know what it is.
Old January 10th, 2013, 11:06 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Bill, is there not two differant styles of that clip? From what I can remember one has tangs facing outwards and the inwards. Or is mt memory fading?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old January 10th, 2013, 11:08 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
I just greased it so it stuck on and stayed in place.
Old January 10th, 2013, 12:17 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Make a search "death clip"
- Charles Eames
Old January 11th, 2013, 04:27 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Someone on another forum had the same problem. They're dead easy when the engine or gearbox is out, but through the slave cylinder hole... nightmare!
I think the cure was a piece of tube, that the pushrod could fit inside,(but not bigger than the plastic clip at the end, so really "just" big enough that the pushrod will fit inside...maybe even splay the end of the tube outwards like little fingers) with the plastic clip in place on the end of the pushrod.
If the piece of tube is shorter than the pushrod, then you can "pull" the pushrod back up into the tube and trap the plastic clip at the end fairly tightly, then try to offer it up to the clutch fork and hopefully get it to clip in place.
Then simply slide the tube back off.
clutch
Clutch master threaded rod nut size/pitch jefhuf Defender Technical Discussions 3 October 3rd, 2012 01:27 PM
Series 3 clutch push rod too short ? kjva Series Technical Discussions 2 May 17th, 2011 08:40 PM
screaming clutch jimmy salmon Defender Technical Discussions 5 November 24th, 2007 12:32 PM
90 v8 clutch problem robheath Defender Technical Discussions 0 August 19th, 2004 06:45 PM
» Defender Registry
#2983
highatp
Summer
StuartL
Add your Defender
