Who has done an aftermarket cam? - Defender Source
Old March 29th, 2005, 12:16 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
I am going to put a cam in my 110I only have 42000 but I have had a sticky lifter for as long as I can remember. The truck is waiting for a friend to weld my frame & I thought I would reseal the engine as it leaks wayyy too much. I would like to know who's cam you all sugg. I will also put in a double roller timing chain.
Do I need new head bolts?
Should I do steel or the newer head gaskets? Any recomendations would be great!!
Peter
Old March 30th, 2005, 05:22 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
bump!!
Old March 30th, 2005, 05:39 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
The guys at D&D engine builders STRONGLY recommend a specific Crower cam (www.aluminumv8.com). The one thing to remember is that you might need new valvesprings too if you are swapping cams. I'd ask the guy what he recommends. That starts to get tricky to do without removing the heads, thought it is possible. I believe they have some tools that use air pressure or other methods to hold the valves in place. If you go with a cam that doesn't need new valvesprings, then you don't have to even worry about removing the heads unless you want to.
IF you do remove the heads, go with new bolts. I used ARP head studs, but regular head bolts will work too at half the price. Choosing between composite or steel is up to you, I went composite for the better sealing, but the composite will drop the compression ratio. Make sure to look up (or ask) for the revised torque specs either way. Definitely spring for the composite valley gasket and newer valve cover gaskets, as they make a big difference for those areas.
If you do it in the truck, you will have to remove the radiator and grill. While it's out, go to a radiator shop and have them put a damned drain spigot on the thing... what a Pain In The Ass without one.
Of all the things to do, you MUST take the oil pump apart, pack it full of vaseline, and prime up the oil system before starting the engine. I used a 12mm socket driven by an electric drill down on the oil pump driveshaft and spun things until oil was dripping out the top of the pushrods.
-Hans
My oil line fix
My 100k stopped odometer fix
Old March 30th, 2005, 06:16 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Thanks Hans! I think I am going with the crower cam, rhodes lifters & undecided timing gears. I am going to take off my heads & have them worked over. I was told that I could reuse my head bolts but?
I am still figurn stuff out. The rad drain is pretty helpful as well I may have the rad recored depending on how it looks..?
Nice heads up on the oil pump prime. I knew about packing with vasiline.
Peter
Old March 30th, 2005, 08:33 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I used a crane cam and lifters from Summit Racing. Works fine. Just another option.
Old June 25th, 2009, 03:16 PM
How much do the composite head gasket lower the compression?
Old June 25th, 2009, 05:26 PM
Grover's Avatar
Grover
Don't know how much the compression changes. I replaced my head gaskets last year with composite gaskets. No noticable change in performance...
Cheers...
Old June 25th, 2009, 10:17 PM
Hans's Avatar
Hans
Hans Haase
Same here, didn't notice any change in performance. I did notice a dramatic decrease in the price per gallon of the gas I could use though. I've been using 87 octane ever since, and not even a hint of a ping. With the original gaskets, I had to always use 91 or 93.
-Hans
My oil line fix
Cam choice kellymoe Defender Technical Discussions 11 February 20th, 2006 01:04 PM
changed cam, all gaskets and now it won't run vesparover Defender Technical Discussions 4 July 24th, 2005 09:56 PM
crower cam not fitting vesparover Defender Technical Discussions 11 July 18th, 2005 11:32 PM
RPI cam or Crane pro's & cons Bowtracer Defender Technical Discussions 1 March 4th, 2005 05:00 PM
DIY Cam replacement, who's done the job kellymoe Defender Technical Discussions 6 December 17th, 2004 12:37 AM
