White steelies with ? tire size - Defender Source
Old July 20th, 2006, 03:51 PM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
Searched but could not find an exact answer. I have 2" OME on the 90, and have recently ordered steel wheels from AB. I want to paint them white when they arrive. AB recommended 235/85-16's. I have 285/75-16's on the alloys now. Will the tires AB recommended look right, or will they be too small? I am no tire expert. Any help will be greatly appreciated.
Old July 20th, 2006, 05:16 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
It really depends on what you want to do. Narrower will give you better mpg and will wonder less on dirt roads at high speed. Wider will generally provide better traction under more difficult terrain. the taller you go the better the clearence but the trade off is higher center of gravity.
235/85 will look a bit on the small size... go with 255/85 or just stick with the 275/85 you are running. IMO 255/85 is a great all around size for a 90.
Old July 20th, 2006, 08:46 PM
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
So, you are suggesting 255/85-16's? I would like to see a pic of these on a 90 if someone has them.
Old July 20th, 2006, 09:07 PM
souza's Avatar
souza
Dave Souza
1995 Defender 90 SW #275
Just had a thread about these tires here:
http://www.defendersource.com/forum/...ead.php?t=4714
I run them on my alloys, I personally feel their a little too narrow for my tastes, but that's probably due more to the offset of the alloy wheel than the tire itself. I like the 285/75 on the 16 inch wheel, I think that'll look great on the steelies you're getting. How wide are they? That's an awefully small tire for for AB to recommend, I wonder if it's a narrow rim.
For comparison, the 255/85 is just over 33" inches tall, and about 10" wide. The 285/75 16 is just under 33" tall and just over 11" wide.
Originally Posted by Mike Hippert
I could run circles around Dave Souzas 90
Old July 27th, 2006, 04:22 PM
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
I went with the 255/85R16's. I will post some pics when they get back from paint and mount/balance.
I hope they look right with the NATO rims.
Does anyone know if I will ned to get hub caps (not really hubcaps, these are much smaller) when I put these on? I didn't even know they existed until I saw them under the Defender parts page on the Rovers Down South website.
Old July 27th, 2006, 10:13 PM
souza's Avatar
souza
Dave Souza
I think those 'hub caps' are like dust caps, and all the trucks came with them. You should be fine.
steelies, tire
MTR Tire Size for OME lift??? TurkD90 Defender Technical Discussions 14 December 5th, 2004 08:44 PM
tire size mfreeman17 Defender Technical Discussions 8 April 18th, 2004 12:16 PM
Boost alloy tire size? ftaube Defender Technical Discussions 6 February 3rd, 2004 11:25 PM
maximum tire size snuffer Defender Technical Discussions 14 November 13th, 2003 09:15 PM
