white smoke...yup electrical short, need help please!! - Defender Source
Old January 20th, 2014, 12:48 AM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
So I upgraded my Defender 200TDI to a 130 amp alternator (whole issue with that) and my headlights were upgraded with a relay (power to fuse block under hood from battery, then to relay). I went to check everything, engine running, battery charging (dual battery, national luna split charge) and then turned on the head lights, they came on just fine but no dash lights (they worked after the alternator went in for a test of a new LED strip for the dash).
any-whoo.....all of a sudden white smoke. shut off power/engine, etc smoke stops. Take the gauge cluster off and it appears that the wire coming from the main harness to the dash gauge lights (not warning light, the actual lights for the gauges) was melted, bare for most of the length of the visible wire.
So....my questions are (I know I have to find why this happened before just replacing things):
1. could the higher output alternator have caused this? (not sure how but just asking)
2. Where to get the multiple wire bullet connector things? (since I will have to redo the whole thing). I have looked at britishwiring.com
3. I know it is hard to sat but is this just a short length of wire that can be replaced easily without taking the whole *&!#* thing apart?
here are the pics:
ID:	88202   Click image for larger version
electrical
300tdi white smoke D90user Defender Technical Discussions 61 October 2nd, 2017 08:38 PM
300tdi white smoke after runaway! Surfin' Elvis Defender Technical Discussions 29 January 19th, 2012 04:28 PM
Fuse keeps blowing (Electrical short) redrockrover Defender Technical Discussions 7 April 19th, 2010 11:45 AM
Random white smoke.. revor Defender Technical Discussions 29 April 22nd, 2009 11:07 PM
Electrical short with my radio ? paulb Defender Technical Discussions 4 August 11th, 2004 12:25 PM
» Defender Registry
RAF
Realm
Dennis
juddy
Add your Defender
