whistling noise from engine - Defender Source
Old December 14th, 2004, 08:05 PM
jstrong98's Avatar
jstrong98
Jon Strong
I'ts been happening for a few weeks now, only noticed it at cold temps, but now its happening at running temp.
Basically, when letting off the accl to slow down, the engine starts to make a whistling noise, and will continue while at idle. The noise stops when I rev the engine slightly, and begins again when I left off the accl.
When getting up to speed, the noise isn't noticed except during shifts , then begins any time I let off the accl.
Does not make any noise at cruise speed.
I replaced the air filter when i first noticed it, but made no change.
I've looked for loose or broken vacc. lines, but I don't see any.
Thoughts ??
JS
Old December 14th, 2004, 08:13 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Alternator bearing? Power Steering pump?
My oil line fix
My 100k stopped odometer fix
Old December 14th, 2004, 11:37 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
The cool thing about the 94's is that you have a different belt for everything. Disconect belts independantly to find the problem. Use choke cleaner and spray around the engine compartment when idleing--if the idle increases, then you have a vaccum leak--but that is not what is causing the whistling--it is coming from a bearing more likely than not. Probably the alternator or the tensioner
engine
Engine Proble: Please Advise saber6 Defender Technical Discussions 24 November 6th, 2009 10:06 AM
Engine Noise coming through Radio? Hammertime Defender Technical Discussions 4 March 10th, 2008 09:42 PM
engine noise. Campbell Defender Technical Discussions 31 October 3rd, 2005 10:34 AM
Curious knocking noise mikeslandrover Defender Technical Discussions 6 March 29th, 2005 06:09 PM
