Whining and clunking when decelerating? - Defender Source
Old October 8th, 2013, 03:58 PM
Quimbola's Avatar
Quimbola
Josh
1994 #1695 Not stock.
Just like the title says, has just started up, definitely is coming from under the vehicle, the noise stops when I push in the clutch, seems to be most apparent when I am in third gear.
I quickly went under the vehicle and all looks seems to fine...
Ideas or thoughts on what ways to check?
Thank you!
-Josh
Old October 8th, 2013, 04:01 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
throw-out bearing comes to mind .......
No Mall crawler here
Old October 8th, 2013, 06:57 PM
WildBoar's Avatar
WildBoar
Derek Borror
109 withdrawals filled by a 110
Yep. Throw out bearing. Just went through this myself. Same noise and effect.
Ended up disintergtating and left me stranded.
"I think we are good...its still dripping"
Old October 9th, 2013, 11:01 AM
Quimbola's Avatar
Quimbola
Josh
What was the cost to replace?
Old October 9th, 2013, 05:16 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
Figure 300 for clutch assembly aftermarket , cut flywheel 75-100 , clutch fork if needed ? , 6+ hr labor without running into problems , $1000 - $1500..total i wouldn't recommend just changing the throw-out bearing not worth it
Old October 9th, 2013, 05:48 PM
Quimbola's Avatar
Quimbola
Josh
Ouch!
Thank you for numbers.
