which tire? which carrier? - Defender Source
Old January 6th, 2008, 02:44 PM
raychel batts
raychel batts
1995 defender
wanted to know if a 285 goodyear mtr would fit under the third brake light? if so, then would it be too heavy for the stock tire carrier? i am putting a old emu lift 2 in. lift on my 1995 st truck and also was wondering if i could get 305 mtr under it and go with the mantec tire carrier. doing away with the third brake light and stock carrier is not a problem but what to do about the excess holes?want the 305 mtr to fit with no trimming involved. sorry if some of this info. has been discussed before for i am new to this game. thanks for any help you may have. raychel
Old January 6th, 2008, 04:36 PM
rovertrader's Avatar
rovertrader
Dale
35/10.50/16 fits on stock carrier w/ no issues. Welcome, and please join us at Uwharrie in the spring.
Old January 6th, 2008, 05:02 PM
raychel batts
raychel batts
1995 defender
thanks for the invite and the info. will the 2 inch lift be enough for the 305 mtr? raychel
Old January 6th, 2008, 05:03 PM
motap
neal
What color is your defender? I'm in Goldsboro...
Old January 6th, 2008, 05:58 PM
raychel batts
raychel batts
1995 defender
the truck is red . i have just had it for two weeks.it is mostly stock,but i plan on changing that.
Old January 6th, 2008, 07:31 PM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
285 or 305 MTR should work with a 2" lift. I used to run 33" BFG MTs with a 2" lift and there was room to spare.
I'd be hesitant about the added weight of the larger tire on the stock carrier- that's just added weight on the rear door hinges, which are weak enough as is. I'd use the larger tire as excuse to go all out and pick up a tire carrier that could accommodate a jack and jerry cans as well. maybe that's just me though.
as for the excess holes- i left mine open, but it'd be easy enough to go down to the local hardware store and pick up some bolts to fill them in.
because six cylinders will take us farther than any president
Old January 6th, 2008, 07:47 PM
raychel batts
raychel batts
1995 defender
thanks for the info that was very helpful. that was the way i was leaning toward. thought that the weight of the tire would be a issue. raychel
Old January 6th, 2008, 07:55 PM
oldscratchggf
nate
95 d90
remember to do extended brake lines
Old January 6th, 2008, 11:15 PM
floyd650's Avatar
floyd650
Alex Lapidus
1994 D90 ST #1716
I scrounged around the small parts drawers at my local hardware store and found some black plastic hole plugs and filled a bunch of hole on the tailgate from the OEM carrier as well as some monster holes on the bonnet from the previous owner's tire carrier.
Old January 8th, 2008, 04:42 PM
bterpstra
Brian Terpstra
94
tire carrier
I don't think the stock carrier is very acceptable for even the stock tire. I put on a kaymar rear carrier that puts all the weight on the rear crossmember. Works well, nicely designed and no more annoying squeaks or rattles (from the tire carrier anyway)
B
carrier, tire
ST rear tire carrier / tailgate rattling... DiscoDino Defender Technical Discussions 9 December 3rd, 2005 06:50 AM
Safari Gard Tire Carrier Joe P For Sale - Parts 10 November 8th, 2005 06:31 PM
Tire carrier problem - bad threads Antonios Defender Technical Discussions 4 May 7th, 2005 09:15 PM
Rear Tire Carrier Joe P Wanted 1 February 15th, 2005 06:45 PM
