Which rear door- galvanized or Puma? - Defender Source
Old August 21st, 2017, 06:55 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
All:
I need to replace my rear door, and I want it to be as corrosion resistant as possible. As I see it, there are two options- an OEM that's been galvanized or a used 'Puma' or gen 2 door from a later Defender.
Link to galvanized one;
https://www.sp4x4.com/DEFENDER_90_11...OR_p/ajc6g.htm
Thoughts? Mine is beyond repair & I bought a used one to fix up, but wasn't planning to have it galvanized- just painted.
Paul.
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old August 21st, 2017, 08:30 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Pretty sure the new doors are are galvanized. Not a heavy coating like you would get by dipping it but the new style galvanized coating that they use on the new cars.
Also the door and skin are made of steel so less concern about dissimilar metals and the frame is stamped so no welds to break.
Old August 21st, 2017, 11:32 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Thanks Dave. The galvy one is a lot cheaper but I'm more concerned about longevity.
Old August 22nd, 2017, 07:57 AM
IMHO go puma unless you are doing some kind of period correct restoration.
Old August 22nd, 2017, 09:00 AM
Rommel's Avatar
Rommel
Rolf
94/95/97 Many
Puma
Does anyone know year specific Puma fitment info for earlier model Defenders.
rolfsauto.com
Old August 22nd, 2017, 09:23 AM
Huh? It's all the same door.
Old August 22nd, 2017, 09:35 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
"Puma" doors fit all years of defender. They started fitting them way back in the 2000's, waaay pre Puma, something like 2003/2004 I think it was.
you just have to change the position of the striker (and maybe the striker itself) as the lock is at a different height.
Don't think any of the parts from the old door will swap over to the new one, maybe the wiper motor if you McGyver it a bit
Old August 22nd, 2017, 10:27 AM
sjpin
Scott P
I bought the SP4x4 galvanized rear door last year and it is a great door. I bought their door because it was cheaper than the puma door and I could use my old door's glass. The puma doors have a different glass pattern and SP4x4 did not have the puma door glass available last year.
Old August 22nd, 2017, 11:27 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I purchased my new style rear door from SP and the glass / seal from Rear Door and Quarter Light Windows for Land Rover Defender
Happy with service from both
Old August 22nd, 2017, 10:26 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Thanks guys. Will my Mantec wheel carrier fit the newer style door?
Old August 22nd, 2017, 10:36 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Mantec makes two door plates. One for the older door and one for the pressed doors. So you might need to replace the plate section. Or maybe you can add the necessary holes depending if the old plate covers all the holes on the new door....
Old August 22nd, 2017, 10:55 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
All:
Paul.
I'd not do the Puma doors - have had a couple come through with rust bubbles on the lower door section as the frame and skin are steel. Early door type with galvanized frames should last as long as the rest of the truck in your intended destination. Additionally you can easily replace the rear glass yourself on the early doors, less so on the puma door.
Old August 22nd, 2017, 11:00 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Thanks Brian. Any experience with these?
https://www.sp-4x4.com/DEFENDER_90_1...OR_p/ajc6g.htm
Originally Posted by Mybluett View Post
I'd not do the Puma doors - have had a couple come through with rust bubbles on the lower door section as the body is steel as well. Early door type with galvanized frames should last as long as the rest of the truck in your intended destination. Additionally you can easily replace the rear glass yourself on the early doors, less so on the puma door.
Old August 23rd, 2017, 09:41 AM
sjpin
Scott P
I have a Mantec wheel carrier on my SP4x4 rear door.
Old August 23rd, 2017, 11:43 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Have some on the shelves... Decent build quality, and with the pound where it is right now the direct price is a few dollars better than my price...
Old August 23rd, 2017, 03:26 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Brian:
What is your price? SP wants 420GBP shipped which is $537 today. 150 quid shipping seems like a lot!
Paul.
door, puma, rear door
Rear diff replacement options cgalpin Defender Technical Discussions 20 July 14th, 2007 01:21 AM
Rear Bench Seat + hardware Chaucer For Sale - Parts 8 September 29th, 2005 12:16 AM
rear roll cage, rear seat, soft top surfd90 Wanted 0 January 12th, 2005 02:59 PM
rear diff and rear seatbelts for '94 D90 rover_rich_d90 Wanted 1 April 20th, 2004 08:54 PM
