which LT230 ratio transfer case for a LS swap? - Defender Source
Old August 23rd, 2014, 04:07 PM
Jwillia's Avatar
Jwillia
Justin
87 ROW build in progress
fellas, I am in the process of building my truck for the GM LS series motor . I am going to use a LT230 case and need to know which one i should go with . I plan on running a tire around 32-33 inches tall. should i go with the 1.2 or the 1.4?
thanks,
Justin
Old August 23rd, 2014, 04:33 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Stock tires are 31.5". The '97 came with the 1.2 LT230Q, you want the 'Q' regardless.
Are you going to drive on the highway much, long trips, or are you going to 'trailer' your rig to events?
Old August 23rd, 2014, 04:36 PM
Jwillia's Avatar
Jwillia
Justin
I am going to drive it on the highway often.
Old August 23rd, 2014, 05:06 PM
With a GM LS series motor V8, I would do a 1.2 without a doubt.
Old August 23rd, 2014, 05:07 PM
Jwillia's Avatar
Jwillia
Justin
Thanks for the input
Old August 23rd, 2014, 05:56 PM
Jwillia's Avatar
Jwillia
Justin
you could even go 1.003 with an LS, although they are harder to come by.
This might be helpful.
http://www.ashcroft-transmissions.co...atio_calc.html
-Jeff
Oh yeah thanks man!
Old August 23rd, 2014, 07:26 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Will there be CARB issues with doing this engine swap into an '87 ?
Old August 23rd, 2014, 08:10 PM
Jwillia's Avatar
Jwillia
Justin
I am sure anything cool is illegal in California
Old August 23rd, 2014, 08:25 PM
Jwillia's Avatar
Jwillia
Justin
There was a time here in the Republik that brand new VW tdi's weren't allowed. We OWN retarded!
-Jeff
Agreed
Old August 23rd, 2014, 09:07 PM
Agreed 1.2 is fine with the Rover V8. There are ratios to about 1.0 from Ashcroft.
Old August 23rd, 2014, 09:18 PM
rovertrader's Avatar
rovertrader
Dale
Justin, I have a near new 1.2 from RN- less than 500 miles, half price of new
Old August 23rd, 2014, 09:21 PM
Jwillia's Avatar
Jwillia
Justin
Thanks I'll see what I find local first, but I'll keep you posted.
Thanks guys I appreciate all the input.
Old August 23rd, 2014, 09:27 PM
Jwillia's Avatar
Jwillia
Justin
The 1.003 is originally from the 2door RRC with the TF727 3speed auto.
-Jeff
Great information thanks!
Old August 23rd, 2014, 10:35 PM
get a q box or somehing from a late model disco be sure is got the cdl nipple, real engines don need gearing
Old August 23rd, 2014, 10:55 PM
-Jeff
I have one, and it is out of a 4 door 1983 RRC.
Old August 24th, 2014, 12:13 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
So will this T-case (1.003) bolt right onto a Zf4HP22 (standard in the '97 D90 & D1) ??
Old August 24th, 2014, 08:50 AM
As far as I know it will. There are adapters, IIRC, for the LT230 to the TF727. I think the only real difference is that it has the higher high range ratio.
Old August 26th, 2014, 02:32 AM
350rangerover
3
The ls has more than enough power for pretty much any ratio
lt230, transfer case
Nylock nut size, rear flange of transfer case - also identify T-case ratio hillstrubl Defender Technical Discussions 3 July 11th, 2012 02:42 PM
LT77 mated to 1.6 ratio LT230 transfer case dogbite For Sale - Parts 5 December 12th, 2011 06:04 PM
Need LT230 T-Case (1.2 ratio) red64chevelle Wanted 5 October 10th, 2011 05:28 PM
LT230 Transfer Case, 1.410 Ratio RyanS For Sale - Parts 23 January 10th, 2011 02:25 PM
1.4 ratio transfer case dave_lucas Wanted 2 November 13th, 2004 02:16 PM
