Which head gasket for 200 tdi - Defender Source
Old May 13th, 2015, 07:58 PM
sandman913's Avatar
sandman913
1985 110 200 Tdi
Is there a way to determine what is the correct head gasket without relying on what is there now? I have the head off and there is clearly a gasket failure. The gasket looks aftermarket and has no tabs or holes. I'm wondering if this is the cause of the failure. Is there a way to tell if I need 0,1,2, or 3 hole gasket? Or what the differences are? I'm going genuine on the gasket to ensure quality, just uNsure which one to use, and what the differences are. Pics of the block/ head numbers attached. Thanks in advance.
Old May 13th, 2015, 08:23 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
Are you skimming the deck? If so, how much?
-Ash
Geared Restoration Co.
352-572-3236
Old May 13th, 2015, 08:29 PM
It is in the workshop manual. You measure the piston stickout.
Old May 13th, 2015, 08:30 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Yes there is a measurement from the piston protrusion. Essentially you measure how far up each piston comes out of the block at four corners. The largest measurement determines the thickness of the gasket. There are write ups on line that will walk you through the procedure. It is that or going with the thickest gasket. The more distance you have from the top of the piston to the gasket the lower the compression. So you really want the thinnest gasket possible.
Old May 13th, 2015, 08:38 PM
My unstated suggestion is that the OP should have a copy of the workshop manual. There are a lot of things that need to be done correctly beyond choosing the right gasket.....
Old May 13th, 2015, 08:42 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
If you skim the head a few thousands it's OK. Use the same gasket as before (but new) as the measurement for the gasket is based off the piston and block. Ask Frita at Turner Engineering for advice on this she is a wealth of knowledge.
Old May 13th, 2015, 08:52 PM
sandman913's Avatar
sandman913
1985 110 200 Tdi
Thanks for the suggestions/ knowledge. I will check the manual and the piston protrusion distances. Other pics attached (didn't come through first time). Thanks.
ID:	120692   Click image for larger version
Old May 13th, 2015, 08:55 PM
tjfslaughter
thomas
Burbon
call Frita in the morning at Turner
Old May 13th, 2015, 08:57 PM
sandman913's Avatar
sandman913
1985 110 200 Tdi
will do- thx
gas, tdi
Changed head gasket now TDI wont start RiftRover Defender Technical Discussions 10 April 3rd, 2015 03:29 PM
head gasket 300 tdi, CavemanDiesel Defender Technical Discussions 3 May 24th, 2014 11:27 PM
Used Proline 200 TDI Radiator & 200 tdi intercooler mgreenspan For Sale - Parts 4 April 8th, 2014 03:38 PM
Looks like my 300 TDi head gasket blew again cdb Defender Technical Discussions 6 July 2nd, 2008 08:27 PM
D90 head gasket lead--which one? Davis Defender Technical Discussions 6 April 1st, 2005 11:52 PM
