which engine is better for a/c 200tdi or 300tdi - Defender Source
Old November 11th, 2010, 07:40 PM
grbec22's Avatar
grbec22
Roger Ramjet
1985 "90" no defender's back then.
can a 200tdi even get ac?
Old November 11th, 2010, 07:43 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
300 is 100 more than 200. Just saying.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 11th, 2010, 09:30 PM
grbec22's Avatar
grbec22
Roger Ramjet
jeez thanks.
Old November 11th, 2010, 11:54 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Thumbs up
hahaha
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old November 12th, 2010, 08:18 AM
draaronr's Avatar
draaronr
Here
LR3
the 300 is far easier to put ac on, if you have a rhd truck with a disco 200 its not too bad to do either, the defender 200 is a pain in the ass. and the 100 more means nothing they are both 2.5tdis
Old November 12th, 2010, 05:01 PM
grbec22's Avatar
grbec22
Roger Ramjet
I have a Rhd. I'm using an LT77 so maybe the 200 tdi is the better choice. Is it a ridiculous job to undertake?
Old November 12th, 2010, 05:17 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
300Tdi is newer than the 200, but even then it's been out of production for 10 odd years.
IMO the 300 is slightly smoother than the 200, slightly less agricultural.
OVer here (UK) 300's are more easily available just because of the sheer number of rusted out discoveries (the disco 300 is exactly the same as a defender type, bar the engine wiring harness... disco 200's have a totally different inlet/exhaust manifold/turbo and front timing chest, which although can be made to fit into a defender, needs considerable faffing about)
The "joy" of the defender spec 200Tdi, is that if you already drive a 2.5 4cyl diesel/petrol, then the 200 will fit straight into the space previously taken by the old 2.5, and bolt up to the gearbox.
IF you want to fit a 300, then (to fit onto an LT77) you'll need to whip the flywheel housing off of the old 2.5 engine and bolt it to the 300, then fabricate some new chassis mounts to bolt the engine too, as the old 2.5/TD ones are different to the 300.
But, bottom line is, you don't need to change the gearbox to an R380 at the same time (although it is a nicer 'box)
How to fit a 300 to an LT77
How to fit a 200Tdi
Both good reading!
Old November 12th, 2010, 06:51 PM
berti1554
Robert Klima
84/110
Originally Posted by diesel_jim View Post
...the disco 300 is exactly the same as a defender type, bar the engine wiring harness...
That's only true for the RHD's...
Old November 13th, 2010, 02:27 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
No it isn't. same for both.
200tdi, 300tdi, engine, tdi
200tdi and 300tdi Engine Versions JimC Smaller Projects 5 January 9th, 2012 09:52 PM
2.25L and 200Tdi engine mounts question Gkase Defender Technical Discussions 8 April 10th, 2009 08:53 PM
Canadian 300Tdi engine on eBay MonLand The Flea Market 5 February 28th, 2009 07:53 PM
300tdi engine for sale d90-110 For Sale - Parts 4 January 6th, 2009 10:54 AM
