Which engine? - Defender Source
Old April 25th, 2008, 11:43 AM
WEMICHENER
Bill Michener
1997 Defender 90
Which engine?
Im coming to the end of my 4.0l V8 in my 1997 D90 and was wondering what year of the 4.6l V8 will just bolt in without any modifications to the tranny and engine compartment. Any help would be appreciated.
Old April 25th, 2008, 03:04 PM
NashvilleRedD90's Avatar
NashvilleRedD90
Will Peters
'97 NAS D90 ST #1704 -4.6
You need the distributor-less gems 4.6, its a P38 motor... I put one in my '97 back in the fall and its a direct replacement. I've put about 4K on it and run Mobile 1 full synthetic and really like it.
'97 D90 - 4.6
'00 D2
Old April 25th, 2008, 03:20 PM
Tim Scully's Avatar
Tim Scully
Tim Scully
95 D90 SW/ 95 RR LWB
Yup you are looking for a 4.6 from a range rover. You are looking for 95-98 year motor. 99 to 02 used a Bousch DIS system on the 4.6. You could use a later model 4.6 you just have to change the crank position sensor mount in the block. They also used the 4.6 in Dicso II for 04, you would have to do some research on that as they may have changed some oil passages in the block for the pickup to the oil pump!
Old April 25th, 2008, 03:57 PM
Any 4.6 short block will bolt in, but if it is a bosch motor you have to swap over the senor plate welded on the back.
If it is a long block, a bosch block will work with a GEMS front cover and the sensor plate (make sure to find one withou air injection or plug the holes in the head).
If it were me, I would find any short block, recondition my existing heads, and fit a new cam, lifters, etc.
A full motor, I would stick with a GEMS motor.
Note, you will have to figure out what to do about the ECU. ECR has access to chips/tuning. The stock one will work but you will not see all the power increase you could.
Ron
Old April 25th, 2008, 06:29 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Ron
Ron, can you just directly swap in a 14cux control until from a 4.2 RRC into a D90 without opening them up and swapping the chips? Just curious as I'm about to do the swap myself.
Robert Deniro
engine
Engine Proble: Please Advise saber6 Defender Technical Discussions 24 November 6th, 2009 10:06 AM
Yet another engine fire chrisvonc Misc. Chit-Chat 80 August 30th, 2005 02:22 PM
???still can't get the trany unbolted from the engine???? kit Defender Technical Discussions 4 October 23rd, 2003 03:20 PM
