Which doors fit will fit my '85 Ninety? - Defender Source
Old October 20th, 2015, 10:09 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
All:
I need to replace the front (driver & passenger) and rear (with wiper) doors on my '85 Ninety. I see ads for NTO doors quite a lot, but before I drop $$$ I want to be sure they will fit. I know LR changed the shape of the rear door at some point, when was that? My current front doors have lift up handles, wind up windows and a galvanized trim piece on the outside. What other years of front & rear doors will fit my Ninety? I would like to go with aluminuim over galvanized frames if possible.
(I searched but couldn't find a definitive answer).
TIA.
Paul.
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old October 20th, 2015, 10:12 PM
any doors from a series 2 on up through puma will fit your truck.
The all steel doors are a considerable upgrade over the alum skin doors
Old October 20th, 2015, 10:21 PM
Originally Posted by Paul K View Post
I would like to go with aluminium over galvanized frames if possible.
Just so there is no confusion. All the frames are steel. There are no aluminum frames. Later trucks used a galvanized steel skin instead of aluminum, which is a very good things as it stops the galvanic corrosion issue. There are also aftermarket doors with galvanized frames and aluminum or galvanized skins.
Old October 20th, 2015, 10:54 PM
When I galvanize a door frame I put a steel skin on that frame. Ally skins suck.
Old October 20th, 2015, 11:08 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
any doors from a series 2 on up to a puma will fit your truck.
Doug:
Okay, so Puma doors won't fit? What year was that?
Any idea on the rear (cargo) doors? Mine is in very sad shape...
Paul.
Old October 20th, 2015, 11:11 PM
Doug:
Paul.
everything from the advent of the series 2 through the end of production December 15th 2015 will fit your truck.
Old October 20th, 2015, 11:12 PM
ATX_D110's Avatar
ATX_D110
Victor
1985 RHD D110 (SOLD)
Contact Scott Pelly "CDN38" for the rear door!!!!!
Old October 20th, 2015, 11:13 PM
He is saying puma will fit.
Rear doors all fit as well including series. Later ones are stronger as they have pressed instead of fabricated frames. And then galv frames ones started to get built.
Old October 21st, 2015, 07:16 AM
I've tried telling Paul that a few times now.
Paul, what Doug said.
Old October 21st, 2015, 09:25 AM
If you like the lift up one piece doors, which are rare you can get replacement skins for them from SP 4x4 in the UK. http://www.sp-4x4.com/category_s/108.htm
Otherwise get the push button type of door. Bolt on and go, though I suspect you may have to change the striker. The the three styles , S3, yours and push button are interchangeable.
Old October 21st, 2015, 07:29 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Thanks guys.
door
Which winches fit SG bumpers? Arcadeus Defender Technical Discussions 16 August 15th, 2015 06:07 PM
White Ninety :: 1990 Land Rover Ninety V8 County gavin. Defender & Series Truck Registry 7 July 24th, 2015 08:58 PM
Which Rover Alloy wheels fit ? Chris Velardi Defender Technical Discussions 1 August 28th, 2010 03:29 PM
'84 petrol Ninety on ebay - not mine hillstrubl The Flea Market 1 July 23rd, 2010 12:04 PM
which tire? which carrier? raychel batts Defender Technical Discussions 9 January 8th, 2008 04:42 PM
