Which door for my 94 ST? - Defender Source
Old May 19th, 2008, 09:29 PM
texmoto
david summers
99 Discovery II
Angry Which door for my 94 ST?
I have searched, but not found what I need. I have a crunched drivers door on my 94 soft top. I have talked to RoversDownSouth and Rovers North. Neither have the door in stock. Both have Series III and 95/97 ST doors. George explained that the 95/97 door will not work because of the travel limiter and I talked to ECR about using the Series door. Again the limiter (aka the rod thingy) is the problem. Also some holes would also have to be drilled. SO, has anyone actually used either door on a 94 ST? If so, what EXACTLY had to be done to make it work. Thanks in advance.
David
Old May 19th, 2008, 10:10 PM
themaxx's Avatar
themaxx
Ade
94 ST
Sux about your door...
Did you see this thread?
Old May 19th, 2008, 10:34 PM
texmoto
david summers
99 Discovery II
That thread did not come up during my mutiple searches. Thanks. Unfortunately, neither option sounds very good. I'm waiting for a quote from the body shop. It will be painful.
Old May 20th, 2008, 07:52 AM
How crunched? Can't you just replace the door skin?
Old May 20th, 2008, 10:20 AM
texmoto
david summers
99 Discovery II
Not that crunched. Not sure whats involved with changing the skin/price/where to get, etc. Doubt if anyone around here knows how either. Had several body shops refuse to work on it because it wasn't steel. Talked with a guy at DAP, am going with a Series door. Said I will need to drill holes for the speaker wire, the interior panel and the lock tumbler (I plan on getting the body shop to do that one). The door is $175 vs $500 for the body shop to fix the old one.
Old May 20th, 2008, 11:26 AM
rayfi's Avatar
rayfi
Derek Moeller
110
I have a willow green 94 door that I plan to convert to use on a 97. I'll trade you for a 97 door if you would like.
Old May 20th, 2008, 07:37 PM
I thought the SIII doors had the same hole for the tumble as the 1994 D90?
Early series doors do not, but the later ones do. I am sure a quick comparison of the two and a little welding or drilling/cutting before paint would get you a match that is more than close enough to be unnoticable.
Old May 20th, 2008, 09:40 PM
texmoto
david summers
99 Discovery II
Well that may be the case for the Series III doors; maybe I'm getting a more plan Series door. And rayfi, PM sent.
Old May 21st, 2008, 08:45 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
The series doors I bought do NOT hade the hole for the tumbler. The door limiter strap issue is of no concern really.. for me...
good luck!
~Steve
door
Fitting a Tickford top on a 94 st Lindy Defender Technical Discussions 4 May 14th, 2009 09:32 AM
Fitting a fiberglass hardtop on my 94 st Lindy Defender Technical Discussions 2 November 21st, 2008 05:07 PM
Thinking of buying a '94 ST Defender Mark M Defender Technical Discussions 19 June 7th, 2004 11:20 AM
car cover for 94 ST with brush bar/no winch Marc Weinstein Wanted 2 April 12th, 2004 12:20 PM
94' D90 ST, 55k miles, 23.5k or Best Offer in CT. januconn92 For Sale - Vehicles 0 February 22nd, 2004 04:16 PM
