which bulb - Defender Source
Old May 28th, 2009, 11:21 PM
Wiley
David Brewer
1995 D90
which bulb
The rear high stop lamp was in pieces when I got this defender. I've kind of glued it back together but can't figure out which bulb it takes. Doesn't look the same as the tail light bulb?
Also has anyone experienced squeeking in the steering wheel. It appears the back of the wheel is rubbing on the plastic housing. Any quick remedies?
Old May 29th, 2009, 02:02 AM
Chaucer
Will
93 110 | 97 90
not sure about the bulb, but for the squeeking, I think you have to loosen the screws that hold the two plastic pieces of steering column (that sandwich together). I think the screws are too tight causing slight bowing - causing the rubbing/squeeking
Need mini dash bulb light replacement Doug Young Defender Technical Discussions 8 January 27th, 2005 07:02 PM
Side Marker Bulb Replacement Matt Klapmust Defender Technical Discussions 8 December 23rd, 2004 06:09 PM
Instrument light bulb / Sylvania replacement Mark M Defender Technical Discussions 2 November 17th, 2004 04:23 PM
Clock Light Bulb ronward Defender Technical Discussions 1 April 28th, 2004 04:13 AM
Side lamp bulb holder Neo Defender Technical Discussions 5 January 30th, 2004 05:07 PM
