Which arb locker fits a 1994 NAS 90 ST? - Defender Source
Old August 26th, 2014, 12:18 PM
DonFromWhitby
Don Andrews
'94 NAS D90 #CDN-80, 2011 LR4
I've been searching around the Faqs, mods and forums and unfortunately, the search comes with a million hits. After an hour or searching, I'm giving up and just asking...
Arb has a few different lockers for defenders.. But which one is for a 1994 NAS 90?
A search on the Arb USA website come up with the following partnos:
RD127 10 spline 3.54 ratio
RD128 24 spline 3.54 ratio
RD138 TC 24 spline 3.54 ratio
RD20 Salisbury 24 spline 3.54 ratio
No explanation is given for which is for front vs rear, or which is used for NAS trucks...
Any help from someone who's done this?
Looking to do rear first, then front later when budget allows...
Old August 26th, 2014, 12:20 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Old August 26th, 2014, 12:21 PM
RD128. Front and rear.
RD127, for 10 spline trucks. Just a really stupid idea....
RD138, for P38 style diffs.
RD20, Salisbury. Basically a Dana 60 used in the rear of pre 2007? 110s and 130s.
Old August 26th, 2014, 12:22 PM
http://www.arbusa.com/uploads/PDF/ac...erDefender.pdf
Old August 26th, 2014, 12:23 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Your truck has a 24 spline axle and 3.54 gear ration so you have 2 choices there. I don't know the difference between the two however so someone else may need to jump in with some help there. Both front and rear are the same btw.
Clay
Old August 26th, 2014, 12:24 PM
And budget to install aftermarket halfshafts and CV joints.... IMO.
Old August 26th, 2014, 12:31 PM
1of40's Avatar
1of40
1of40
X2 especially if you only go rear and plan to run larger/heavier tires over challenging terrain. But with that said I'd rather break an axle than blow a diff.
Old August 26th, 2014, 12:46 PM
And I should add.... You are better off getting an Ashcroft air locker than an ARB. They have a better design.
Old August 26th, 2014, 12:50 PM
If you have to ask these questions, just buy a rear locker as well. You don't need a front. The extra cost to make these late model axles strong enough for a locker is unreasonable for the benefit.
Old August 26th, 2014, 01:27 PM
DonFromWhitby
Don Andrews
All interesting points. I had forgotten that Ashcroft made an air locker.
Maybe they'd put together a package with the locker and half shafts...
What should I be looking for in uprated CV joints? The truck is stock height, but I'm looking to add a 90mm lift and go from the 285/75/16 Goodyear MTRs (i think that works out to 32" OD?) to something bigger with some wheel spacers ( I have some rubbing now with these tires)
The MTRs work well for me, but they're very loud.. The truck sees about 3000km of driving a year and in terms of split between highway and trail, I usually drive about two hours to the trail at highway speeds, then spend a day or two in the bush at low speed.
Otherwise, I'm about 10 minutes from my favourite green lane where I can get the kids a bit bumpy and a little muddy with no risk of body damage or getting stuck. I'm debating getting more road worthy tires and if I get stuck, relying on my winch. I'm looking to do some tougher trails with some of the local 4x4 clubs where they are recommending 35" tires and. 4" lift (mind you a jeep needs more lift than a D90) for some of these trails with difficult rock passages.
Thanks!
Don
Old August 26th, 2014, 02:38 PM
For the CVs, I would get the Rovertracks kit. http://lucky8llc.com/Products.aspx?ProductID=7881 Best deal out there.
90mm lift? Are you serious? Why? That is a big lift for a 90 and has a lot of downsides. In addition, doing it properly is very complicated.
Old August 26th, 2014, 02:49 PM
DonFromWhitby
Don Andrews
Typo.. 50mm
And thanks for the link.. Looks like a good quality kit..
Old August 26th, 2014, 05:33 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
i'll have front and rear ARB's with 4:11 for sale shortly......
good luck with your search
Old August 26th, 2014, 05:37 PM
1of40's Avatar
1of40
1of40
I would recommend you speak to Lucky8 or Great Basin Rovers. Explain to them what you intend to do in the near and long term. They will be able to give you advice on what to do first, etc. These are both well respected in the industry and will guide you on options to consider.
If you are going to be doing trails that need that type of vehicle prep there are other issues you should be aware of and take into consideration.
I just think it's tough to ask the general public questions like this and keep from getting even more confused.
Clay
Old September 14th, 2014, 10:03 AM
DonFromWhitby
Don Andrews
Asking price and condition?
Old September 14th, 2014, 11:41 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
If you don't get Ron's arbs, get the Ashcrofts with half shafts /cvs
Old September 14th, 2014, 11:56 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
X2 but I would go with the tibus/rover tracks cvs.
Old September 14th, 2014, 12:19 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
That's the config I'm running with my MTR's right now...no problems whatsoever. And if you're doing all of that half shaft and CV's is the smart way to go...sell the old or keep as trail spares. Good Luck!!
Old September 14th, 2014, 12:40 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
My bad...stuck in D2 mindset where Ashcroft is the only option haha
1994, 90, nas
For Sale/Trade: Discovery 2 (99-02) ARB Bumper (Fits D1) honda50r For Sale - Parts 7 September 18th, 2013 04:11 PM
More Locker talk _ Detroit Locker. CDN90 Defender Technical Discussions 5 May 6th, 2010 10:56 PM
which tire? which carrier? raychel batts Defender Technical Discussions 9 January 8th, 2008 04:42 PM
Factory Nas '97 bumper or bumper that fits a xd9000i warn winch Frankie Carbone Wanted 1 July 6th, 2007 07:05 PM
Arb Locker Tech Manual (.pdf) online, courtesy of ARB USA Cube II Misc. Chit-Chat 4 December 5th, 2006 04:28 PM
