Where's the bl**@y coolant going? - Defender Source
Old December 13th, 2004, 03:39 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Well after 100,000 miles of trouble free motoring (well relatively) the 200 tdi in my 110 is starting to use water at an alarming rate- 2 litres in about 50 miles. The anoying think is I can't see where it's leaking from
This is potentially not good - head gasket maybe)?
Strangely it lost no water with the header tank cap removed on the return journey so that in a way points to it not being the headgasket, at least the combustion gasses aren't pressurising the system. There aren't clouds of steam from the exhaust so water probably isn't getting into the combustion chambers.
The water must be being forced out by the pressure generated within the cooling system, but where?
The engine has been a little slow to start in the mornings lately but I don't know if that's connected.
Any suggestions?
Mike Hammond
Old December 13th, 2004, 03:59 PM
pin hole in the radiator that only opens when there is pressure? Do you have a way of pressurizing the cooling system with the engine off? Like one of those pressure testers? Just an idea, if it is a leak you could always crack an egg in it.
Old December 13th, 2004, 04:22 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Check your heater core also, if it's leaking in the heater box it would either be dumping out the drain hose or maybe pooling in the heater box. Turn your windshield blower on full, and look for the coolant on the inside of the windshield.
-Hans
Oh, and just out of curiosity. Have you checked the transmission bellhousing? Remember, you DID have fluid coming out of that in the past. Could be a freeze plug in the back of the block.
-Hans
My oil line fix
My 100k stopped odometer fix
Old December 13th, 2004, 05:19 PM
rolaro
Jan-Dirk Roodbol
1985
Check the dipstick of the oil; no contamination? kind of brown sludge?
Take off the nut on top of the radiator, and look on the waterlevel if it is pulsating by running motor.
By a headgasket faillure it is possible that the gasket is broken in the dirtection of the piston, or "oil channel".
An other possibility is that a hoseclip has cut the hose after a while.
Pressuring the system what Mike wrote is also a possibility, but take care; the thermostat , when the engine is cold, block the whole system.
The difficult thing is that you warme up the radiator, and the leak vaporized directly.
Good luck anyway.
Tell us how you solved the problem
Jan-Dirk
Old December 14th, 2004, 09:25 AM
mikeslandrover
Mike Hammond
-Hans
Well remembered different truck though.
I found the leak this afternoon. Pin hole in the pipe going to the heater matrix. Expansion tank cap off- no leak, cap on slow leak, hardly left a trace on the bulkhead but there was a whitish deposit on the pipe and a bit of a spurt if you twisted the pipe about a bit. I replaced the heater matrix about 2 months ago, no doubt when that went, the inside of the truck turned into a sauna - couldn't see a thing out of the windows. Had to use the force to steer/navigate
Mike H, I was devising a cunning plan to pressurise the cooling system involving a header tank cap drilled out to accept an ordinary tyre valve but there's a snag.... the overflow pipe would need to be blocked off, hadn't quite thought of a way of doing that when the cause of the leak became apparant. Possible some sort of blanked off tube. Might build it on the basis of it would be a useful thing to have in the tool chest.
Thanks for all the useful suggestion, it turned out to be a relatively cheap and easy leaking hose.
Mike Hammond
coolant
Engine Coolant what kinda rover4x4 Defender Technical Discussions 12 May 17th, 2009 11:02 PM
coolant - which to use scoloco Defender Technical Discussions 37 May 2nd, 2009 04:24 AM
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
Coolant hose leak - cure in a can question michael15 Defender Technical Discussions 3 May 21st, 2005 11:36 PM
Small coolant leak near distributor Neo Defender Technical Discussions 4 May 4th, 2004 01:44 PM
