where to source side window felt - Page 3 - Defender Source
Old March 18th, 2012, 08:04 PM
Funny, i am just catching up on threads and then will post a little writeup on my install. I swear the instructions on mine include removal of the little bumpers, but now that you mention it I didn't put them back in (nor do I see any need to).
I got #6 x 1/2" pan head phillips screws (crown bolt brand from home depot). I have not tried them yet (just stole one from another door top) but they look to be an exact match by eyeball. I'll go fit one later and comment here if for some reason these are not right.
I just drilled the old screw out carefully and was lucky to keep it on center, so I just rummaged for a screw that looked the right size at the time and used it to re-cut the threads. It took a few times of just getting it to turn one or two revolutions with lots of pb blaster as a cutting lubricant to cut some threads into the aluminum.
Originally Posted by pendy
I'm here for the D's
Old March 18th, 2012, 08:19 PM
proulx70's Avatar
proulx70
Paul S.
1997 NAS BRG Soft-Top
Chris,
You are correct, it's not in the version of the instructions you have, but we did film it for the video we are working on and it will be in the next printing of the instruction manuals. Some will have this issue, some won't; it varies from vehicle to vehicle. This is why I'm only printing the manuals in small batches!
Yes, just pry it out with a screwdriver or pull it out will needle-nose pliers, then replace when done.
Hope you like the results you get from the kit!
Best,
Paul
Originally Posted by chris snell View Post
Paul,
Got my kit in (great packaging, by the way) and started installing it today. I noticed that I cant slide the rear glass forward enough to access one of the channel screws because there is a small rubber bumper in the way. I didn't see it mentioned in the instructions but I assume that I just pop that bumper out with a flat screwdriver?
I snapped a head off one of the damned screws, too. What a bummer. Besides drilling and tapping it, I need to source a whole new screw. Charles, what size tap and screw did you choose to replace the sheared one?
I think I will soak the other screws in PB Blaster to hopefully prevent this from happening again.
Old March 18th, 2012, 08:20 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Not having much luck removing this rubber bumper. How did you pry yours out without destroying it?
It's funny how it's easier to rebuild a rear axle on a D90 than it is to do little things like fix a window rattle, fix the leaky vent seals, or install a tow jaw.
Old March 18th, 2012, 08:23 PM
Perhaps wait for Paul to confirm they are not needed after putting in his seals, but mine were more of a closed cell foam type of material and didn't come out entirely unscathed. I don't recall but it would have been either a small screwdriver or needle nose pliers. But I didn't put mine back in and I don't think I will.
Old March 18th, 2012, 08:29 PM
proulx70's Avatar
proulx70
Paul S.
I prefer to use needle-nose pliers. Just get a good grab on the end and then pull out. When you go to put it back in, it's helpful to squeeze the foam with the pliers to compress it. That will help you get it started. The foam is really dense.
I know, sometimes the easiest things can be the trickiest. Believe it or not but the install on the rear sliding windows on the hard tops is a WAY easier as job. It seems like it would be more difficult a job with having to drill out all the rivets, but the install on the removable door tops is definitely the trickier of the two.
Thanks for the comment on the packaging!
Keep me posted.
Best,
Paul
Old March 18th, 2012, 08:52 PM
proulx70's Avatar
proulx70
Paul S.
Charles,
Chris is referring to the hard rubber bumper that stops the inside window glass when you push it all the way forward.
Curious about your install and tips you would have for others. I consider the instruction manual a 'living document' that can always be improved. It's hard to cover every possible situation in a little booklet and no one wants to read a novel for something like this, but I'm always looking for ways to make it easier for the next customer.
Best,
Paul
[QUOTE=cgalpin;337884]Funny, i am just catching up on threads and then will post a little writeup on my install. I swear the instructions on mine include removal of the little bumpers, but now that you mention it I didn't put them back in (nor do I see any need to).
Old March 18th, 2012, 08:55 PM
Writeup here:
http://www.defendersource.com/forum/...d.php?p=337902
I didn't remove the rubber bumpers in the window bottoms, but I think mine didn't have those screws, because I stole 2 screws from another window to finish this install and only broke one But I believe I removed that screw on the other window without sliding it any further forward than it's usual position.
Old March 18th, 2012, 09:04 PM
I just checked and these are the right size.
Old May 19th, 2012, 02:19 PM
proulx70's Avatar
proulx70
Paul S.
Installation Videos & Armed Forces Rally Team
We have created installation videos for these kits. We are still doing to the voice-over and editing on the Soft Top kit, but the Rear Window kit video is now up on our YouTube page. Hopefully we'll have the Soft Top kit video up in a month or so. (slowwww process!)
You can check it out at http://www.youtube.com/GarrisonOutfitters
Also, the Armed Forces Rally Team in the U.K. is now running our kits on all six of their Rally Wolf vehicles! I have attached a couple photos showing them installing our product.
Here's a quote from their team director:
“Many thanks for the provision of your window kits which have worked very well in both stopping the constant and annoying rattling and also the automatic vibratory closure of the windows whilst out on the special stages!” A Paramore MBE, Major, Team Director, Armed Forces Rally Team
I am traveling to Scotland to join the team at the Jim Clark Rally the first weekend in June and will report back on the sure-to-be-exciting weekend! You can check out the rally at http://www.jimclarkrally.com/
You can learn more about the Armed Forces Rally Team at http://www.armedforcesrallyteam.com/ They have many great photos and videos up on their site. Check it out!
Best regards,
Paul
ID:	51819   Click image for larger version
ID:	51821   Click image for larger version
Name:	Rally Team Photo.JPG
Old July 31st, 2012, 09:32 PM
proulx70's Avatar
proulx70
Paul S.
Press for Rubber Window Channel Kits
Our products are mentioned in the 'New Stuff' sections of the August issue of Land Rover Owner International magazine and the September issue of Land Rover World magazine.
We also have a growing Facebook community. Come join us! http://www.facebook.com/garrisonoutfitters
Name:	Land Rover World Magazine Cover Sep 2012.PNG
ID:	54947   Click image for larger version
Name:	Land Rover World Magazine Insertion Sep 2012.PNG
ID:	54949   Click image for larger version
Name:	LRO New ProductsSmall.jpg
Old August 28th, 2012, 11:22 PM
proulx70's Avatar
proulx70
Paul S.
New Product Video - Featuring AFRT
Check out our new video featuring great shots of the Armed Forces Rally Team's Land Rover Wolf vehicles in action. Also includes a product testimonial from the Team Director.
Old December 5th, 2012, 08:44 AM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Paul, is the PayPal link still kosher? I'd like to place an order for the rear sliding window kit. Thanks!
Old December 5th, 2012, 10:44 AM
proulx70's Avatar
proulx70
Paul S.
The links are still good.
The promotional pricing ended a few months ago though. The kits now retail for the regular price of $129.99, but still with 10% off for D-90 Source members.
Best regards,
Paul
Old May 1st, 2013, 08:56 PM
proulx70's Avatar
proulx70
Paul S.
European Distributors
For those in Europe... our Replacement Rubber Window Channel Kits are distributed by AllMakes 4x4 and Bearmach Ltd! Contact your local dealer and end that window rattle once and for all!
Follow this link to read the announcement from AllMakes 4x4: http://www.allmakes4x4.com/blog/allm...tters-products
Follow this link to read the What's New page from AllMakes 4x4: http://www.allmakes4x4.com/whatsnew/garrison-outfitters
AllMakes 4x4 Catalog Numbers:
GAL400 - Removable Door Top Kit
GAL401 - Rear Sliding Side Window Kit
Bearmach Limited Catalog Numbers:
BA180 - Removable Door Top Kit
BA181k - Rear Sliding Side Window Kit
Thank you to these two great companies for distributing our products.
Best regards,
Paul
ID:	71235   Click image for larger version
Old July 15th, 2013, 06:37 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
Bump for a great product. I just installed my window kit from Garrison Outfitters and wow is it better! Super easy to do and couldn't be happier with the results. Thanks Paul.
Old July 15th, 2013, 07:26 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
X2...
Old July 15th, 2013, 10:12 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
X3--I did mine last month.
Old July 28th, 2013, 12:21 PM
proulx70's Avatar
proulx70
Paul S.
New Bearmach Catalog Released
Our window kits with catalog numbers are featured on page 10.
http://www.bearmach.com/books/Defender/index.html
Best,
Paul
Name:	Screen Shot 2013-07-28 at 9.10.38 AM.jpg
ID:	76550   Click image for larger version
Name:	Screen Shot 2013-07-28 at 9.09.17 AM.jpg
Name:	Screen Shot 2013-07-28 at 9.09.33 AM.png
Old February 12th, 2014, 08:51 AM
proulx70's Avatar
proulx70
Paul S.
For our European customers, our Replacement Rubber Window Channel Kits are now available through MUD-UK, along with our Under Seat Storage Cases.
Check out MUD-UK for unique and original products for your Defender!
http://www.mudstuff.co.uk/products/g...utfitters.html
End that window rattle once-and-for-all!
Best regards,
Paul
Name:	Screen Shot 2014-02-12 at 5.39.05 AM.png
ID:	89555   Click image for larger version
Name:	Screen Shot 2014-02-12 at 5.39.25 AM.jpg
Name:	Screen Shot 2014-02-12 at 5.38.47 AM.png
Old April 12th, 2014, 10:25 AM
J. Andrew's Avatar
J. Andrew
J. Andrew
95 D90 NAS SW #384
Does anyone know the LR parts number to the plastic tracks?
http://www.roversnorth.com/ProductDe...e=0&eq=&key=it
felt, window
Need measurements for SW side window placement dave_lucas Defender Technical Discussions 17 May 30th, 2009 05:14 PM
Side Window Guards Zeke Wanted 8 February 3rd, 2005 08:49 PM
D90 SW side window trim wanted Chris Cox Wanted 0 January 26th, 2005 05:09 PM
Plastic parts from driver side window?? Vadim Defender Technical Discussions 1 January 18th, 2005 03:06 AM
Soft Top Side Window Bar boshea Wanted 2 June 18th, 2004 08:14 PM
