Where to put extra gauges when fitting new style TD5 dash? - Defender Source
Old May 9th, 2011, 09:00 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Prior to switching to the new TD5 style dash I was using a mud console to hold my radio, switches and 3 extra gauges now I am having a hard time trying to find a place to install the extra gauges with the new TD5 style dash.
Speedo, tach, Water temp, Fuel, Boost, EGT, clock
Already planning to lose the clock but that still leaves me with 2 homeless gauges.
Not really a fan of mounting them on the dash in a mudpod as I do not like the way it looks.
Any ideas?
Only somewhat clean idea I can come up with is mounting them on the bottom of the center dash using a custom billet mount
Old May 9th, 2011, 09:36 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
This thing is pretty cool.. Saw it a while back.
Here is a forum discussing it: http://forums.lr4x4.com/index.php?showtopic=18350
Here is the company web site: http://www.madman.co.za/
Old May 9th, 2011, 09:44 PM
bjf's Avatar
bjf
barry f
94 ST #395
That thing looks awesome
Old May 10th, 2011, 09:22 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
you could use a gauge pod on top of the dash or on the "A" pillar. Haven't seen it done or how it would look, but it would work. I had thought about putting the gauges in the center of the console where the cigarette lighter is?
Land Rover 110
Old May 11th, 2011, 12:37 PM
PaulMc's Avatar
PaulMc
Paul McConnell
1989 110 2.5 Turbo-Diesel
You can get gauge holders designed to fit into a DIN cutout -
Flat type -
http://cgi.ebay.com/ebaymotors/New-S...Q5fAccessories
Angled type -
http://cgi.ebay.com/Single-DIN-radio...item5d2eb365cf
There are quite a few on eBay, do a search for 'DIN gauge'
Paul.
1989 Arles Blue 2.5TD 110 Hardtop
1999 Epsom Green Discovery II 4.0 V8i 'XS'
Old May 11th, 2011, 05:18 PM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Or make your own
Old May 11th, 2011, 05:25 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Paul > No free space to fit a DIN setup.
Kevin > I have a TD5 dash and they do not have the free space in that are
That madman setup looks neat, not only would I retain my boost / EGT I would gain battery voltage and have the optio0n to monitor a bunch of other stuff.
I am going to send them email them and see if it will work with my 200tdi and where to buy them.
Still open for other ideas in the mean time
ID:	38620   Click image for larger version
Old May 11th, 2011, 05:38 PM
kevkon's Avatar
kevkon
kevin
Can you use the Mud Console ? I thought it was similar in size and mount to the TD5.
Old May 11th, 2011, 06:10 PM
PaulMc's Avatar
PaulMc
Paul McConnell
I see
I fitted my Head Unit into a Tuffy Console a few years before I fitted the TD5 Switch Console, so I have the DIN slot free to play with.
ECR have done a Double-DIN mod to the TD5 Console, this would give you space for a Head Unit and 3 x 52mm Gauges -
http://www.eastcoastrover.com/207A.html
Paul.
Old May 11th, 2011, 07:30 PM
bjf's Avatar
bjf
barry f
94 ST #395
I like that gauge in the dash cluster. Wonder how hard it is to tie into everything.
Old May 11th, 2011, 10:04 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
Depending on if you want to get new gauges you can consolidate some of the gauges, ie on my regular dash I have EGT/Boost on one gauge and Water Temp/Oil Temp on another.
You CAN use the Mud console and I highly recommend. It is way more robust than the Td5 as it has a thick aluminum "liner" or backing. In addition the supporting structure of the Mud console is a lot more solid than the Td5. You will have to hack and cut into the Td5 and essentially cut it in half and then install the Mud console "into" the the bulkhead and then build the Td5 around it.
I've got oil pressure and tranny temp on the left with both batteries on the right. There is a digital tach (TinyTach) in upper left which also gives engine hours and max RPM memory. There is Espar control in the upper right. Seat heaters at bottom.
I think it looks great and is a lot more robust and bulletproof than the Td5 console. Also a bit better organized for gauges and switches, etc.
I've got a head unit with Nav that folds out. Fits into a single DIN.
Here's some pics.
Pendy did the work but the gauges were my idea
ID:	38624   Click image for larger version
ID:	38626   Click image for larger version
Old May 11th, 2011, 11:05 PM
dsh12
Daniel Hayes
1994 Defender 90 Soft Top
Very nice setup John!
* What is the make of the combo gauges (website)?
* What head unit is it?
So you have the diesel fueled (from the fuel tank) cabin heater?
Dan
94D90 NAS 3.9 LT77 LT230T Soft Top
There are no guarantees expressed or implied of the accuracy or correctness of the contents of this message, and the Author is not liable for the taking of any action in reliance upon the contents of this message. As always, do your own research. To the extent that opinions are expressed in this message, they are not necessarily the opinions of the Author.
Old May 11th, 2011, 11:50 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
hide the words
Thank you.
Westach.......www.westach.com
Kenwood
It is the hydronic so it heats the engine but it's set up in series with the heater box so it puts out heat for the cabin that way.
dash, td5
Rockware(Warn 8274) style Winch Bumper, Tire Chains Set and Aluminum Dash Cowl MTC280 e90miller For Sale - Parts 11 January 29th, 2010 06:24 PM
Genuine TD5 Dash SafariHP For Sale - Parts 11 February 18th, 2008 10:48 PM
Center Dash Fascia for Gauges Hoss Wanted 15 March 3rd, 2006 03:58 AM
bulkhead and wiper stud fitting problem mattdh Defender Technical Discussions 3 April 2nd, 2004 09:42 AM
Dash Removal pcarey Defender Technical Discussions 8 March 6th, 2004 11:32 PM
