Where to mount ARB Locker switches - Defender Source
Old June 20th, 2007, 08:19 PM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
Where has everyone been mounting ARB switches? Finally taking that plunge and would love some pics. I want to make it clean, or even hidden. I searched and have seen the Range Rover classic switches, and headlight switch trick.
Old June 21st, 2007, 12:01 AM
stevewhitaker's Avatar
stevewhitaker
Stephen Whitaker
1994 D-90
Not being a smoker, I put my 3 switches where the ashtray used to go, running the wiring up behind the facia. They fit quite nicely in the modified ashtray receptacle and are out of the way; not easily hit accidentally. I have them slanted so they are easy to see from the driver's or passenger's seats. I'll try to get pictures tomorrow.
Old June 21st, 2007, 08:29 AM
btate
Bryan Tate
d90
I cut holes just to the right of the instrument cluster on the upper facing portion of the parcel tray.
(Way to the left of the cig. lighter)
The wires easily come out on top of the tray and are wrapped nicely.
It is a nice out of the way location. (got the idea from DrAaron)
He has a pic, or I can send you one.
Carefull cutting the metal is double thickness in some spots
Old June 21st, 2007, 10:20 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Series III dash, can use them without looking with my hand still on the shifter in 1st.
Old June 21st, 2007, 12:54 PM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
Here is where I mounted mine. I used a piece of 2X2 aluminum angle. I attached it with industrial Velcro. I can take the switches off if I need access to the fuse box, and the best part is no drilling/cutting. The "blank" switch provides switched power to the system instead of using an ignition hot lead. That way you do not need to have the key on to activate the lockers. Handy for changing a tire or parking on slopes or uneven terrain.
--Benjamin Franklin
Old June 21st, 2007, 03:28 PM
themaxx's Avatar
themaxx
Ade
94 ST
I just picked this truck up on Monday, and it came loaded with goodies! If you need close up pics of the ARB switch, let me know...
Old June 21st, 2007, 03:34 PM
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
I'm really considering putting them where the dash light dimmer switch is, on the left side of the steering wheel on the dash. I've already moved the dimmer switch up above the panel. There was a blank already cut out for it there. So, now I have a perfect space for three switches. Does anyone see any problems with putting them there?
Old June 21st, 2007, 04:06 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
Shawn thats where i just put mine.Rear locker only for now. Youll only have to legthen the hole a little. The only issue I had is the PO modified the dash and I had to do some cutting. It shouldnt be a problem but for feeding the wire up from the console thru the dash.under the dash panel and down.
Old June 21st, 2007, 07:44 PM
themaxx's Avatar
themaxx
Ade
94 ST
Shawn, you want to do something like this, but with the ARB switches....
Name:	Switch location.jpg
Old June 22nd, 2007, 03:18 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Smile
My previous cubby box...now I have a new one but the switches are the same...
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old July 20th, 2007, 05:11 PM
stevewhitaker
Stephen Whitaker
1994 D-90
Here are two pix of placing the ARB switches in the former ashtray.
Name:	ARB Switch1.jpg
ID:	9842   Click image for larger version
Name:	ARB Switch2.jpg
Old July 20th, 2007, 09:32 PM
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
I ended up putting them where the dimmer switch goes. I moved the dimmer switch up where the blank was for another switch. Looks pretty factory. Holds the 3 switches there perfectly and no glare from the switch lights. I'll post a pic when I can take a picture.
Old July 22nd, 2007, 05:00 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
This is what I did. If memory serves, there is space for two additional switches (other than the current dash light/dome light stuff). The hole are a little two small for the ARB switches, but my two switches are there.
I do not have a "master air compressor" switch yet, only the two (front and rear) locker switches. Right now, I unplug the compressor for non-wheeling days..... Someday..... I'll put that master switch somewhere.
But that also means that no one can play "what does this button do again" while driving (or not).
Originally Posted by JSBriggs
If you like the ARB switches, and want them for other accessories, you can get them here www.waytekwire.com search for CONTURA
-Jeff
Thanks! I wish I'd known that a year ago! Any idea where to find the "old style" ARB switches? The CONTURA are rocker switches, my D90 came with a rear ARB and with a push-button switch. I like the push button better (even if it looks bulkier/non factory).
MonLand
1995 D90 NAS
1996 Discovery NAS
Old July 22nd, 2007, 07:57 PM
draaronr's Avatar
draaronr
Here
LR3
well I am sure it is too late, but here is what I did that btate mentioned.
ID:	9855   Click image for larger version
Old July 31st, 2007, 02:49 PM
flynn23
Scott Kozicki
97 NAS D90 SW
Where did you get your switches?? I'd like to use this same style for my trail lights.
Old July 31st, 2007, 04:47 PM
MonLand
Loic Fabro
-Jeff
Scott, is that what you are looking for?
MonLand
1995 D90 NAS
1996 Discovery NAS
Old August 1st, 2007, 03:04 AM
themaxx's Avatar
themaxx
Ade
94 ST
Hey Scott, if you're talking about this switch? You can buy them from EE for $70 each or from BP for $25 each. Here's the part # PRC5425.
Peace
Old August 1st, 2007, 06:33 PM
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
The Contura rocker style switches can be purchased from West Marine or on ebay. Search ebay for Contura rocker switches.
Old August 1st, 2007, 06:58 PM
Gore Ranger's Avatar
Gore Ranger
Jeff
1989 RRC
Peace
That's the RRC headlight switch. Watch the boards for someone parting out a RRC and offer them $5 for it.
Old August 2nd, 2007, 11:31 AM
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
English Swedish Spares has those RRC swithces. Call and ask for Lee and tell him you need some.
mount, switch
Need ARB locker install manual dave_lucas Defender Technical Discussions 13 December 6th, 2006 11:05 AM
Arb Locker Tech Manual (.pdf) online, courtesy of ARB USA Cube II Misc. Chit-Chat 4 December 5th, 2006 04:28 PM
ARB locker (used) Steve Rupp Wanted 0 July 31st, 2005 11:14 PM
Rear ARB Locker RickM Defender Technical Discussions 4 April 20th, 2005 12:22 PM
ARB locker TwisteD90 Defender Technical Discussions 2 December 2nd, 2003 11:26 AM
