Where to get cheap snorkel/intake rubber hose like the one from Mantec? - Defender Source
Old December 14th, 2011, 05:14 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Question Where to get cheap snorkel/intake rubber hose like the one from Mantec?
Just curious where you guys buy your intake hoses like for ex: MAF to intake plenum? I also used the hose that came with my mantec snorkel for this purpose as well, but wondering wheres the best place to get this stuff or something comprable. Thanks all help is appreciated.
Robert Deniro
Old December 14th, 2011, 05:43 PM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
Summit Racing...bought hose there when I made the snorkel for my Range Rover.
They make a non-melting/fireproof type hose...
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
Old December 14th, 2011, 05:52 PM
If you want brutally stout, then go to your favorite marine supply and order Shields exhaust hose. Shieldsflex is a corrugated version that takes tight bends a little better. Here is a about it.
If you want rigid fiberglass tubing, the name to look for is "Vernatube", who make straight and bends. It can be ordered here.
Old December 14th, 2011, 05:58 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Grainger
Semper Fi!
Old December 14th, 2011, 06:16 PM
dchapman
Daniel Chapman
1999 D1
Peep McMaster Carr. Search PVC hose. Look for the stuff that's wire reinforced. Should be able to buy it by the foot. They've probably got it in several colors, including pink. You seem like a pink kinnda guy.
Old December 14th, 2011, 06:40 PM
Neil McCauley
Neil McCauley
I figured mcmastercarr would have it. Guess I just need to measure the pipe. Fleshlite intake hose!?
Robert Deniro
mantec, rubber, snorkel
Power Steering hose - major pain... timtimtj Defender Technical Discussions 15 May 4th, 2012 01:40 PM
OEM Rubber Andrew Vick Misc. Chit-Chat 2 January 27th, 2007 07:24 AM
Stupid vacuum hose Mike Hippert Defender Technical Discussions 7 November 9th, 2005 09:00 PM
air intake hose?? / source for cheap switches NASD90 Defender Technical Discussions 15 July 6th, 2005 02:40 PM
97 low pressure A/C hose source dnewman9 Defender Technical Discussions 1 June 15th, 2004 01:39 AM
