where to get an'84 d-90 ROW ignition switch - Defender Source
Old May 26th, 2012, 03:01 PM
isleofbones's Avatar
isleofbones
Mike Deery
1984 D-90
I have a Does anyone know who carries an '84 d-90 UK spec ignition switch. I don't know about the NAS d-90s, but my ignition turns toward the driver as opposed toward the front bumper (the opposite of traditional american cars). Thanks.
Old May 26th, 2012, 03:30 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Try Rovahfarm:
http://rovahfarm.com/defenderignitionpage2.htm
MUDSUX
Old May 26th, 2012, 04:10 PM
isleofbones
Mike Deery
1984 D-90
Thanks, that was my first thought, but they are closed until sometime in June when they complete their move from
Vermont to somewhere out west. I kind of need it now. By the way, I guess it should mention that my truck is a 200tdi. Accordingly, the accesory position on the ignition controls the glow plugs.
Old May 26th, 2012, 04:37 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Crap sorry! I am sure you tried all the usual suspects. Maybe George at Rovers Down South or Stephen at SafariHP. Good luck.
MUDSUX
Old May 26th, 2012, 06:24 PM
isleofbones
Mike Deery
1984 D-90
Thanks again... will try other sources mentioned.
Old May 26th, 2012, 07:22 PM
triple9music's Avatar
triple9music
Chad Davis
1984 Defender 90
I'd go for safarihp.
Old May 26th, 2012, 08:10 PM
Isn't the switch on partsgeek.com the same for ROW trucks as it is for NAS? That's where I got mine for the 110 ($17).
Old May 26th, 2012, 08:44 PM
isleofbones
Mike Deery
1984 D-90
Jason-
I don't know if it is the same.... That is one of the things I am trying to determine.... You wouldn't happen to have a part #. Anyway, I see that the switches change through the years for the range rover. I am curious if it has changed from 1984-97 for the d-90. Any expertise on the issue would be welcomed.
Old May 26th, 2012, 09:01 PM
Do you have a pic of your current switch that you can post?
Old May 26th, 2012, 09:12 PM
Here's the one I was referring to:
http://www.partsgeek.com/catalog/199...on_switch.html
Old May 26th, 2012, 09:17 PM
isleofbones
Mike Deery
1984 D-90
I will try to get pic tomorrow. Partsgeek item looks similar to my 1984 Haynes manual pic, but spades are perpendicular to each other in Haynes pic. Parts Geek has the oem item with all spades parallel to each other. I will dig in to my ignition tomorrow.
Old May 26th, 2012, 10:04 PM
Mike:
Also, I wouldn't worry too much about not having the glow plugs position on the switch...this time of year it's not needed.
Old May 29th, 2012, 03:00 PM
kpmatt00's Avatar
kpmatt00
Matthew Mozelak
1985 D-90
Does anyone know if this worked yet? Sunday night my wife left the ignition swith inthe start position while driving, (spring was weak) which also broke the starter. So i need both parts - any ideas on a 1985 2.5 petrol engine starter would be great!
1985 Land Rover Defender 90
Old May 29th, 2012, 03:10 PM
I was actually working with Mike on this, and the thing that threw me was the reverse side (away from the spade terminals) on the 2nd switch from parts geek shown here:
In a nutshell, I'm familiar with the backside of the switch shown here (which has a female receiver on the back made of plastic that slips into the ignition switch housing...though not shown here I'm sure most know what I'm referring to):
Name:	ignition switch1.jpg
The backside of the 2nd switch shown here looks like a different connection...that's where I got stumped. I asked Mike to send me a pic of his switch out of the housing (which is easy to do) so we could troubleshoot and see if the part looked to be compatible:
Name:	ignition switch2.jpg
of course if anyone knows better than I please chime in.
Old May 29th, 2012, 04:09 PM
kpmatt00's Avatar
kpmatt00
Matthew Mozelak
1985 D-90
I guessing it is the first - althogh mine just needs a new spring so I may have just bought a $30 spring. As for the starter I asked about, I found it here - http://www.paddockspares.com/parts-a...cessories.html
Thanks Jason
Old May 29th, 2012, 04:13 PM
The thing that was throwing us off was Mike's had the blades that are "perpendicular" to each other (similar to the 2nd photo) versus the blades that are parallel to each other (as in the 1st photo).
Old May 29th, 2012, 08:53 PM
kpmatt00's Avatar
kpmatt00
Matthew Mozelak
1985 D-90
Yeah - that would throw me off for sure - is it sorted now? Maybe try asking someone like Mike at Riverhouse or ECR, or just try both...Thankfully I think I'll be back on the road in a few days, only been registered a few weeks!
Old May 29th, 2012, 08:56 PM
isleofbones
Mike Deery
1984 D-90
Thanks guys, I think I've located the exact item I need to replace through Trevor at Rovahfarm. Although he is in the process of moving, he was kind enough to respond to an email and send details, pictures.
90, d-90, switch
Removing Faulty Ignition Switch - It's STUCK rijosho Defender Technical Discussions 20 March 29th, 2017 12:54 PM
wiring of ignition switch mattdh Defender Technical Discussions 1 October 4th, 2006 01:50 PM
Removing ignition switch crobinson Defender Technical Discussions 5 January 3rd, 2006 06:33 PM
