Where to get a cheaper starter???? - Defender Source
Old October 12th, 2006, 09:38 AM
bd90
94 Arles Blue #1644
Does anyone know of a different brand of starter for a '94 D90? I mean is the LR starter the same as a GM or Ford (or some other manufacturer) but with a different part number? How about an aftermarket starter for a Disco from a parts store chain (for less $$)? $400 to $600 is a little ridiculous especially when I just dropped $500 on cooling system parts. A cursory search of the FAQ Section on the great article on part conversions was unsuccessful.
How about rebuilding the starter. Do you think a local shop could rebuild it or is it an oddball starter setup?
Old October 12th, 2006, 09:53 AM
themaxx's Avatar
themaxx
Ade
94 ST
http://cgi.ebay.com/ebaymotors/LAND-...spagenameZWD1V
http://cgi.ebay.com/ebaymotors/START...spagenameZWD1V
http://cgi.ebay.com/ebaymotors/NEW-S...spagenameZWD1V
Old October 12th, 2006, 09:55 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
my dealer has them for 199
Old October 12th, 2006, 10:06 AM
I am going to need one too. I have heard of people changing to the Mean Green starters, they average around 299 on the internet. Any thoughts would be appreciaed.
In a previous post, I have also read that you can repair your stock LR starter.
Old October 12th, 2006, 10:33 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
I have the Bosch units rebuilt locally with a new drive, brushes, and solenoid for about $200. I used to be able to buy new from the dealer for about that price, but things are changing and prices have gone up recently (thanks, Ford)...retail for a new Bosch starter was quoted at $420 last week with a $140 core charge.
I use a local rebuilder that does a lot of rebuilds for forklifts and other equipment. Apparently a lot of that equipment uses similar Bosch starters and parts are readily available. They can generally turn it around in 3 days or so.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old October 12th, 2006, 01:20 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
My "Land Rover" starter is stamped Bosh. I recently decided to open it to rebuild it. Someone mentioned that it is in fact using standard parts (well brushes and solenoid) that I can get for about $50 total.
In the process I also learnt of a good address to get a new one for cheap:
http://www.defendersource.com/forum/...4402#post74402
HTH,
BTW, I had bought replacement brushes from Atlantic British (http://www.roverparts.com/) but they _do_not_ fit my starter, so open/check it out before you order parts!
MonLand
1995 D90 NAS
1996 Discovery NAS
Old October 12th, 2006, 01:34 PM
bd90
94 Arles Blue #1644
Fabro, so you're saying that the Bosch unit is Bosch in name only?
Thanks for all the advice. After I posted I thought that if my battery is bad that could be the cause of the ticking noise when I turn the key. If so I won't need a starter but with my luck the battery will be in tiptop shape. If its the starter, I'll see about the rebuild option first and then try to find a $200 replacement somewhere.
Fabro, I re-read your post. Now it makes sense. The starter has genuine Bosch parts but to rebuild it yourself you can use standard brushes, etc. to fix. Sorry about that. Brian
Old October 12th, 2006, 01:50 PM
MonLand
Loic Fabro
Yes, this is a Bosh starter. My understanding is that such starter has been widely used and (Bosh?) parts are widely available. I can't speak for the 1994, but I would assume this is the same starter? I have the part numbers of the starter and solenoid if you want to compare with yours.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old October 12th, 2006, 04:56 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Loic -- for some reason I didn't realize you were in Herndon . . . anyway, Arlington Armature (which is actually in Alexandria) can rebuild the starters quickly and fairly inexpensively. Same with alternators.
Old October 12th, 2006, 08:10 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Mean green suck. I had two of them and gave up on them. They didn't like working in the not really cold of winter in Va.
Jimmy Buffett
Old October 13th, 2006, 08:35 AM
I think autozone had the bosch and lucas for around teh 200 spot
Old October 13th, 2006, 03:03 PM
MonLand
Loic Fabro
I was quoted about $280 at my local Advanced Autopart. BUT, this was for a rebuilt (i.e. not a brand new one!).
New and rebuilt is not the same thing... ;-)
MonLand
1995 D90 NAS
1996 Discovery NAS
Old October 15th, 2006, 01:31 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Had a mean green on my Range rover and liked it. I had it some seriously cold weather and snow but never experienced problems. Opposite case of Tyler's above, the stock selenoid kept feezing up in the winter and I could never get the truck to start. If I remember correctly I had to buy some extra battery cableing because the mean green does not fit up with stock wiring very well. I think this problem is amplified in Denfenders. Could be wrong though. The reason I went with the mean green was simply because it offered a lower gear ration than the stock starter which was something i wanted in the cold winters my car was seeing.
Old October 17th, 2006, 08:04 AM
Andrew Vick
Andrew Vick
95 D90
Got a new in the box starter from Nathan Crabtree at www.discountbritishparts.com for $148 or so. No issues whatsoever and Nathan is awesome to deal with.
Old October 17th, 2006, 08:52 AM
flippedrover
Tyler
'94 D-90
I loved the Mean Green when it worked. I accidentaly found out one day that I can actualy start the truck in gear and the starter would get me moving fast enough to keep going with just a little gas. I'd like to get another high torque starter just so long as it works in the winter.
Jimmy Buffett
Old October 19th, 2006, 07:41 PM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
Bought my Bosch-design from a place in Lorton VA for $210. Found them through a local search on "alternator" "rebuild" "starter" for keyworkds
start, starter
Starter issues on my D90 Rover- Girl Defender Technical Discussions 13 February 13th, 2010 10:59 PM
Compatible starter motor question? MiniGuy Defender Technical Discussions 14 January 3rd, 2006 10:58 PM
Starter solution for TD D90? torque Defender Technical Discussions 0 April 30th, 2005 11:10 PM
Starter going bad? loykd Defender Technical Discussions 6 September 15th, 2004 10:12 PM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
