Where to find a Panhard Rod? - Defender Source
Old June 3rd, 2013, 09:16 PM
isleofbones's Avatar
isleofbones
Mike Deery
1984 D-90
So, my mechanic said I needed a new front tracking rod. I inquired among the experts here and got some very helpful advice about the front tracking rod and the tie rod ends. So, when I called my mechanic to confirm before I ordered, he said, "NO, it doesn't have tie rod ends, it has bushes at the ends and supposedly this part, which I have come to learn is a panhard rod, along with a steering stabilizer, will supposedly eliminate the play in my steering wheel. I can;t recall any play in the steering before I replaced my steering box with a remanufactured one from meridian ( to the tune of almost $400). Anyway, can anyone tell me where I can find a panhard rod assembly stateside for a ROW 1984 rhd defender 90? Have found later years. Thanks
Old June 3rd, 2013, 09:28 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
I have one, but you really just need to replace the bushings.
Old June 4th, 2013, 06:26 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Get an adjustable one from Lucky8. Terrafirma makes a nice one. But it should only be the bushings.
Semper Fi!
Old June 4th, 2013, 06:31 AM
The Dro
Dro
1988 Ninety
I think I have one... You can have it for shipping cost.
Old June 4th, 2013, 08:29 AM
isleofbones
Mike Deery
1984 D-90
You guys I am sure are right, I probably only need the bushings... it doesn't look bent. It looks like a heavy piece of steel. However, I guess I will need the bushings. Does anyone know where I can get the bushings for a 84 ROW d-90 rhd? Are they commonly available from Roversnorth or any of the other common sources?
Thanks again for the input. If I actually need the rod itself, I will let you guys know and take you up on your generous offers.
Old June 4th, 2013, 09:30 AM
RoversNorth
RN
2012 Land Rover Defender
Indeed we do!
http://landroverparts.roversnorth.co...ANR3410&type=0
http://landroverparts.roversnorth.co...=PLS049&type=0
Rovers North
1319 Vt Rt 128, Westford, VT 05494
Please message me with any questions you have.
Old June 4th, 2013, 09:55 AM
isleofbones
Mike Deery
1984 D-90
Thanks Zack. Just ordered the bushes and steering damper from Rovers North, along with incidentals.
Old June 4th, 2013, 10:04 AM
RoversNorth
RN
Thank you for the order! Cheers
Rovers North
Panhard Rod Bolts kellymoe For Sale - Parts 2 October 27th, 2005 07:18 PM
RoverTym Adjustable Panhard Rod cbass For Sale - Parts 3 August 16th, 2005 12:41 AM
Adjustable Panhard Rod with Heim Joints RyanS Defender Technical Discussions 21 August 12th, 2005 08:33 PM
Panhard Rod Bushing Question JBurt Defender Technical Discussions 3 December 31st, 2004 08:45 PM
Help!!! broke zerk and bent panhard rod Milo Defender Technical Discussions 3 June 14th, 2004 01:43 PM
