where to buy Rotella 5W40, in Mass - Defender Source
Old December 6th, 2008, 03:53 PM
artm
Arthur Maravelis
97 SW
Anyone in Mass using this oil (synthetic)? Used to get it at WalMart but no longer - at least the ones I visit. Ran out of 5 gal jugs and need to restock soon.
Old December 6th, 2008, 05:24 PM
pmd's Avatar
pmd
Paul Dandini
None :-(
This past summer I bought some Rotella oil at AutoZone on Mystic Ave - might want to call them..
Old December 6th, 2008, 09:41 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Our Shell rep said it was out of stock and it may be discontinued. I haven't been able to get any for a month or so.
Matt Browne
Old December 6th, 2008, 10:06 PM
artm
Arthur Maravelis
97 SW
Paul,
Was that a blue bottle or white? Blue is Rotella-T (synthetic).
Matt,
Rotella-T in May 20008 introduced CJ-4 and now it's discontinued?! If you can keep me posted on your progress I wouldn't mind buying a supply off you - if that's agreeable.
In the meantime I'll start looking around.
Old December 6th, 2008, 10:43 PM
pmd's Avatar
pmd
Paul Dandini
None :-(
Arthur,
I don't recall the color - but I have a couple gallons at work.
I did a quick search on their website
http://www.autozone.com/selectedZip,.../selectZip.htm
Shell / 1 gal. SAE 5W-40 Rotella T Synthetic Motor Oil
Part Number: 5079769
Weight: 24.42 lbs
$19.99
Availability:
Store: Normally stocked at your local store.
Online: Not Available
hope this helps..
Old December 7th, 2008, 09:16 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
Art, my bad....the wholesaler I deal with (marine) is not going to carry it as there is so little demand. The Shell rep at the marine shows doesn't even display it any more. However, Shell is not discontinuing it .
[QUOTE][Matt,
Rotella-T in May 20008 introduced CJ-4 and now it's discontinued?! ][QUOTE]
Is that a reformulation or something? I've been using their synthetic for several years.
Matt Browne
Old December 7th, 2008, 11:53 AM
artm
Arthur Maravelis
97 SW
CJ-4 is the newest spec, the main difference bewseen it and the older CI-4+ is TBN. A brief review in some VW TDi forums says the older formulation is better in this respect and many are stocking up on it, if they can find it.
TBN has to do with an additive in an oil that prevents or controls acid buildup over extended change intervals. Doesn't affect me as I change at normal intervals.
Here's a link to more info on that:
http://www.blackstone-labs.com/do_i_need_a_tbn_.html
Old December 7th, 2008, 06:33 PM
junkyddog11
oil soaked filter
95 RRC 300tdi
....not a big fan of the extended change intervals either. Not considering the relatively hard life my junk leads.
Matt Browne
Bling Master J's Stainless Steel Bolt Kits - Group Buy JimC Misc. Chit-Chat 67 April 11th, 2012 12:47 AM
Tell me why I should/should not buy a D90 fustogrande Defender Technical Discussions 44 March 2nd, 2006 11:57 AM
Looking to buy: 1997 D90, red or green hardtop rcrafte Wanted 0 December 9th, 2005 01:16 AM
GROUP BUY - HD Seat Covers from UK, All Models... RedRhinoProducts The Vendors Loft 0 December 10th, 2004 10:48 AM
Group Buy: Gas Tank Skid Plates SlickRockFab The Vendors Loft 53 September 20th, 2004 10:13 PM
