Where to buy NAS 110 Oil Cooler line replacements - Defender Source
Old November 25th, 2015, 10:34 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Where is the best place to buy stainless braided lines with all proper adapters for an NAS 110? I bought my adapters for mine from ECR but their site says they are no longer selling the parts. Only available for onsite install only.
Suggestions?
Old November 25th, 2015, 10:37 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Suggestions?
I'd suggest you look for a local industrial hydraulic supply house that will make custom lines. Bring in your current ones and have them replace the flex sections with braided SS - this keeps the stock fittings and prevents the cobbled together adaptors that you would end up with.
Old November 25th, 2015, 10:48 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Eric Brown at Trailhead, he makes killer kits! I have installed a half dozen this year, highly recommend his product.
Old November 25th, 2015, 10:57 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Suggestions?
If you have the radiator adapters already then you don't need anyone's kit.
You can get all the 8AN fittings and hose right from JEGS or Summit Racing (or any other place that sells AN fittings).
------ Follow up post added November 25th, 2015 11:00 PM ------
This does not however solve the issue that Rover stupidly ran the lines right next to the RH exhaust manifold.
One of the many benefits of going with AN style hoses is that the lines are moved far away from the hot manifold, and when quality parts are used it is superior in every way to the Rover fittings.
Email:
Old November 25th, 2015, 11:09 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Originally Posted by ECR;691911
[SIZE=1
No disrespect meant, I'm sure you've done about 1K times more replacement lines than we have. But our solution does solve the issue if you specify a length that allows the lined to be run away from the manifold (as we have done a few times for customers). An easy solution that makes for a clean installation without aftermarket parts (not disparaging the quality of other suppliers, just simplifying the solution for a few people who prefer.
Old November 25th, 2015, 11:22 PM
ECR's Avatar
ECR
To each his own, but the factory lines have long sections of hard pipe on each end that dictate where the flex line will go (and you can't use a thermostatic oil plate if you wanted to). If you extend the flex line you can get into issues with the AC filter/drier, especially on the early 1994 NAS 90s, and you can't truly route the line away from everything like you can when you make your own.
See the image. The hard pipes force the lines to be in bad places and unless you went really long on the flexible part you are still going to be in non-ideal locations.
We have also seen the stock lines with braided hose leak a good bit (because it is a crimp, not a full fitting) and in a couple of cases crack the radiator solder holding the oil cooler in place due to the weight and leverage. Adding more flex pipe would make that issue worse.
We are all for Genuine parts but the oil lines are a case where Rover got it dead wrong. Going with the stock parts over race proven superior aftermarket parts is not something we would suggest to any customer, especially after all the Defenders we have had to rebuild due to fires. YMMV.
NAS Defender oil line upgrade
Email:
Old November 25th, 2015, 11:44 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Wow - looking at that pic that Mike @ ECR posted it looks like LR tried to get the lines as close as possible to the header pipe. Seems like there is a nice clean run straight across and clearing the header by a lot.
I used Trailhead lines on my NAS 90 years ago. For my current build I used AN fittings and it worked out well from the OM617 oil filter to a 200tdi radiator. The AN fitting are straight forward to work with.
Old November 26th, 2015, 08:42 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Mike, can you share your opinion on removing them all together for NAS applications? I don't believe the ROWs came with lines unless you ordered as an option an external oil cooler. I saw one once on a ROW I brought over from CH.
Old November 29th, 2015, 08:32 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Thanks for the help. I will send all of this info onto the owner.
Old January 31st, 2016, 08:20 AM
ben little's Avatar
ben little
ben little
1986 ex-MOD 110
I'd like to hear more about this as well. Doing a restore on my 110 now and although I'm temporarily keeping the little 2.5na, I'd like to remove the shitty oil cooler/ lines.
I recall reading somewhere on the board that ex-mod trucks (like mine) were only fitted with Oil Coolers so they could idle for days on end while radio transmitting.
Old January 31st, 2016, 09:22 AM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
X2 I have put these on all four of my defenders I have owned over time.
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old April 25th, 2016, 01:16 PM
RX6RCROL's Avatar
RX6RCROL
Matthew Hedrick
1994 D-90 #646
Summit racing oil cooler line fail. I did not assemble these, previous owner did. Hose came out/squeezed out of the fitting. I reassembled it on the side of the road, got oil, drove on to Uwharrie. Click image for larger version
ID:	148063 Click image for larger version
ID:	148065 Click image for larger version
ID:	148066 Click image for larger version
110, ac, nas, nas 110
oil change/oil cooler line change sirjond Defender Technical Discussions 12 January 25th, 2013 03:01 PM
200tdi oil cooler / oil cooler line thread question dave_lucas Defender Technical Discussions 7 September 26th, 2012 11:56 AM
Fuel line replacements red&yellowrovers Defender Technical Discussions 5 September 22nd, 2012 11:25 AM
stock adapter between oil cooler and oil cooler lines dave_lucas Wanted 3 December 23rd, 2009 03:33 PM
Group buy - Rover Acc oil cooler line setup artm For Sale - Parts 24 October 11th, 2005 10:36 PM
