Where to buy ? - Defender Source
Old December 23rd, 2010, 08:33 PM
Where to buy ?
A couple of years ago @ Uwharrie Mr. Galpin, Mr. Bobeck and myself came upon a pair of Birts in a 88 who had twisted a rear axle shaft off in the wet red slime and rocks that is Uwharrie.
After pulling the hub they reached in the truck and pulled out a two part aluminum tube with a very strong magnet in the end. They used this tool to pull the broken splined axle stub out of the diff very effectively and quickly.
I want one. Can anyone point me in the right direction ?
Old December 23rd, 2010, 09:24 PM
IPSC_GUY's Avatar
IPSC_GUY
Peter/Lesbo
1983 110, 1985 110, 1993 110...
Wow I want one too but I have never seen one commercially available. I bet someone could make ya something with a Rare earth magnet in the end. Maybe even an electro-magnet?
IPSC_GUY
SIERRA II ALPHA
Old December 23rd, 2010, 09:37 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
Harbor Freight, Sears, Mac Tools and of course Snap On
Old December 23rd, 2010, 09:59 PM
Oxcart13's Avatar
Oxcart13
Mark M
D110
Doug - A fine gent here in the Denver area named Jim Hall made these devices - jim.hall@solihullsociety.org. If he's not making them anymore, I'm sure he could pass on enough data for you to make your own. Mark
Old December 23rd, 2010, 10:15 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
I think the guys at X Eng make just that tool, go to their website should be right there. I believe it was one of their first items that they were selling.
Old December 24th, 2010, 01:13 AM
Bingo
http://www.x-eng.co.uk/X-Shaft.asp?MID=33
Thanks !
Old December 24th, 2010, 03:01 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Possibly another group buy opportunity?
Old December 24th, 2010, 07:38 AM
lucky8 has em
Old December 24th, 2010, 08:12 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Originally Posted by rover4x4
lucky8 has em
Yep, I have one. You can find them pretty cheap on eBay too.
Semper Fi!
Old December 24th, 2010, 07:51 PM
meatblanket's Avatar
meatblanket
Mike Simpson
1955 86 1986 ExMOD 110
Or you can make your own tool that is superior to the magnet tool.
http://gunsandrovers.yuku.com/topic/...ng.html?page=1
Old December 26th, 2010, 03:24 AM
Thanks for the heads up on the series diff tool Mark and Mike.
Pretty sure that won't work on the Salisbury axles I deal with. I used the ground rod trick since I have a detriot locker with no spiders but that really isn't a field repair since poth axles need to be pulled and the rod long enough to push the broken stub all the way through. That said the magnetic tool works on all and gets the little shards as well.
Old December 26th, 2010, 10:03 AM
meatblanket
Mike Simpson
Whoops! That's correct, that fork style tool is for Rover 10 spline axles. If you don't have spider gears, and no cross shafts, then all the better-- you don't need the fork! Note that the aluminum tube is used to catch the broken stub that you push out from the opposite side. So the length of the rod only has to be slightly greater than half the width of the axle. You store the rod inside your aluminum tube.
The magnet tool is going to be easier to use, provided it works at all. Sometimes the broken stubs are twisted in there really tight, and can be a bugger to dislodge. The magnet isn't going to get those out, but beating on it from the opposite side almost always works. If you already have one of the magnet tools, then you might think about carrying both tools-- you wouldn't need the aluminum tube if you had the magnet tool, but the rod could still be used to beat stubs out if you can't get them dislodged with the magnet.
It's always a good idea to epoxy a magnet to the inside of your drain plug to pick up any metal shards to get you home for a gear oil change.
Old December 28th, 2010, 02:47 AM
This is going to sound totally off the wall, but i had an old spare tire release rod from a Ford Explorer lying around (used to drop the spare like a crank rod...real long and skinny, you fed it into a slot in the back of the car and cranked the tire down). Anyhow, this thing has to be 4' long or more, so when my stub axle broke in the series I ground one end down and it worked perfect to bang out the stuck bits.
Now, on the other end - and I'll warn you this is McGyver territory - I cut a cardboard paper towel tube in half, duct taped it to a stick, and used it to catch the piece(s) that fell out. I now keep these tucked behind my bench seat along with an extra stub axle.
Totally ghetto I concede, but gets the job done and will be food for thought if this happens to anyone on the fly.
Old January 4th, 2011, 07:00 PM
Gardner's Avatar
Gardner
Gardner Congdon
'84 RHD D90 300Tdi
For those interested in a diy...
39lbs of pull (!)
http://www.kjmagnetics.com/proddetai...038DCB&cat=173
-Gardner
Bling Master J's Stainless Steel Bolt Kits - Group Buy JimC Misc. Chit-Chat 67 April 11th, 2012 12:47 AM
Tell me why I should/should not buy a D90 fustogrande Defender Technical Discussions 44 March 2nd, 2006 11:57 AM
SS KITS group buy Sam_rover For Sale - Parts 13 January 23rd, 2006 10:34 PM
GROUP BUY - HD Seat Covers from UK, All Models... RedRhinoProducts The Vendors Loft 0 December 10th, 2004 10:48 AM
Group Buy: Gas Tank Skid Plates SlickRockFab The Vendors Loft 53 September 20th, 2004 10:13 PM
