Where is the difflock switch located? - Defender Source
Old January 6th, 2012, 12:38 AM
Hi folks,
Can anyone tell me where specifically on a disco 1 transfer case the difflock lamp switch is located? This is the switch that illuminates the dash light showing the diff is locked.
I am trying to track down the wires for it. I found the reverse switch without much issue but the difflock seems to be another matter...
Old January 6th, 2012, 02:12 AM
headdamage's Avatar
headdamage
Andrew
exmod 90 2.5na and a 93/RRC 200tdi
It is on top of the front output housing of the LT230 behind the diff lock selector and close to the main box.
http://homepage.mac.com/noahlmil/ima...mple_case1.jpg
Old January 6th, 2012, 11:04 AM
thank you!
Old January 6th, 2012, 11:37 AM
Naplm00
Matthew
before you put your floors back on, turn on the truck and make sure the new one is adjusted for depth properly, if not it may not turn on or it could be on all the time
switch
Wiper motor limit switch replacement LenB Smaller Projects 5 June 7th, 2012 07:29 AM
Headlight Switch Issue, any ideas? januconn92 Defender Technical Discussions 1 July 24th, 2005 11:53 AM
P/N for heated windshield switch mgrgpg Defender Technical Discussions 5 November 12th, 2004 08:19 PM
