Where is my Coolant Leak? - Defender Source
Old October 28th, 2008, 09:21 PM
61rover's Avatar
61rover
John Crouse
I have a very strange combination of symptoms. Turned on the heater and got a foggy windshield. I assumed the heater core was leaking, but I couldn't find a leak. (I'm going to pull the cover off the heater/AC this weekend to be sure). So I let the truck sit for several days and then fired it up this evening. I have moisture in the exhaust and I think the coolant looks a little low. I'm actually getting a drip at the Y-Pipe to exhaust joint.
Looks to me like a head gasket. Just wondering if there are any other possibilities.
Old October 28th, 2008, 09:37 PM
CDeWan
Clay DeWan
5.3L beastie
I ran into a coolant leak 2 weeks ago. No one laugh.... I undid the coolant tank cap and put my finger over the overspill little hose on the side of the tank and put my mouth on the coolant tank refill spout and blew into it. Found the leak as I could hear it. Just a suggestion. You could also try stiking in a rubber plug of some type and pressurizing the system similiar to the above.
Old October 28th, 2008, 09:45 PM
There's no conceivable way that a headgasket leak can manifest itself as a foggy windshield, and its not uncommon to have moisture buildup in the exhaust, so I'd say if the foggy windshield persists, its the heater core.
Old October 28th, 2008, 10:53 PM
61rover's Avatar
61rover
John Crouse
Coolant Leak
I did think about the two problems being unrelated. (On a Rover?) We'll see.
I bought a heater core just in case. If there is anyone else that needs a new heater core for the NAS 110, I think I found a source. I ordered it from an outfit I've never dealt with before. If they deliver, the price is 1/5 what they cost here.
Old October 29th, 2008, 12:41 AM
Chaucer
Will
93 110 | 97 90
I had a foggy windshield from turning on the heater...After thinking it was something like a heater core etc., it was the heater intake was full of water. There's rubber drain in the heater intake that gets clogged...then it fills with water, then you get a foggy windshield when you run your heater.
Old October 29th, 2008, 05:54 AM
I was suprised at how much stuff can accumulate in that drain, probally best to clean it out a few times a year if your truck lives outside.
Old October 29th, 2008, 10:32 AM
Please keep us posted on NAS 110 heater core. Since I have mine out I want to replace it now.
coolant
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
Coolant Leak - Help! mlw911 Defender Technical Discussions 6 March 15th, 2006 11:08 AM
Coolant hose leak - cure in a can question michael15 Defender Technical Discussions 3 May 21st, 2005 11:36 PM
coolant leak jperakis Defender Technical Discussions 2 February 27th, 2005 02:39 AM
Small coolant leak near distributor Neo Defender Technical Discussions 4 May 4th, 2004 01:44 PM
