where is drain plug for the swivel housing - Defender Source
Old July 22nd, 2007, 03:38 PM
UpnOver's Avatar
UpnOver
David Williams
'97 Yellow ST
I need to change my oil of my swivel housing to one shot, but where is the drain plug for it? I stupid q's, but i dont see it.
Old July 22nd, 2007, 04:29 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Look for a square-head screw.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old July 22nd, 2007, 05:11 PM
UpnOver's Avatar
UpnOver
David Williams
'97 Yellow ST
i see the square head on top in front, but isn't there one on the bottom to drain it?
Old July 22nd, 2007, 06:13 PM
Cirbo's Avatar
Cirbo
Jim C.
If you have a '97, (which I see you do) there is not one. Your truck came equipped with the "one-shot grease" from the factory.
jC
Old July 22nd, 2007, 06:19 PM
UpnOver's Avatar
UpnOver
David Williams
'97 Yellow ST
Jim,
I replaced to gease with gear oil when I had to take out the axel and cv when I put my new gears and lockers in it. Can I pump out the oil or do I have to take the whole hub off?
Old July 22nd, 2007, 07:45 PM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
I would just add more Genuine LR Lube to top it off. Pumping it i think would be hard since it is kinda gooey unless gear oil has crossed over the seal from the diff.
--Benjamin Franklin
Old July 22nd, 2007, 08:15 PM
UpnOver's Avatar
UpnOver
David Williams
'97 Yellow ST
I will try it, but here is a bad cell phone pic of the seal.
Old July 22nd, 2007, 09:52 PM
BlackDog
A. Fehd
95 90ST
I'm having the same problem from drivers side swivel ball - couldnt figure out the light metallic sound coming from the front wheel and couldnt see any leaking fluid from the swivel ball itself. Finally powerwashed the mud/trail crap off and let it sit and have a oil leak, at least what's left in the housing is still coming out. Anyone had luck using the LR "one shot" grease instead of redoing the oil seals?
95 Beluga ST
Old July 23rd, 2007, 06:18 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
If you really need to drain the grease you can remove one (and only one, doesn't matter which) bolt from the lower swivel.....remove the fill plug for a vent and then spend several days waiting for it to drain. Slight pressure from an air hose will help. Adding some diesel or Kero first and driving around the block will thin it all down.
Grease will not fix damaged seals.
IMPORTANT: be sure to re-install the lower swivel pin bolt correctly
Matt Browne
Old July 23rd, 2007, 07:39 AM
Cirbo's Avatar
Cirbo
Jim C.
I agree with Mike. Just add some oil. I would worry about that metalic sound though...!
Old July 23rd, 2007, 03:23 PM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
Since we are on this subject again, if the seals are bad does that mean that the 80w90 diff fluid can freely flow in and out of the swivel housings?
And, is this okay as long as there are no leaks?
Should I leave it alone until they finally do leak?
drain, drain plug
Drain Plug Diffs/Xfer Case Grover Defender Technical Discussions 7 November 11th, 2009 11:21 PM
Looking for a RH Swivel Pin Housing D110DC Wanted 7 November 1st, 2009 10:42 PM
Long post regarding CV Joint/Swivel housing.. Emerson00 Defender Technical Discussions 16 June 12th, 2007 09:11 AM
swivel pin housing - grease or oil or both? cgalpin Defender Technical Discussions 27 March 9th, 2007 09:16 AM
Interesting swivel ball problem dameek Defender Technical Discussions 1 July 24th, 2005 01:18 AM
