Where does this wire go ? (electrical question) - Defender Source
Old January 16th, 2005, 11:25 AM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
<attached image>
I had to rewire some PIAA lights and in the process while working only near the location in the attached image, unknowingly broke this wire loose from something. (a piece of the 'male' connector is still attached to it.)
Needless to say, the D won't start.
Fuel pump turns on, plenty of juice from 2 (new) Optima batteries, turns over but no start.
I don't think it's the PIAA lights because they're on their own wiring & battery.
If anyone can shed some light on the situation... Much appreciated.
Nicholas
Old January 16th, 2005, 11:40 AM
Are there any wires missing from the bottom of the coil? Looks like it may be one of them.
Old January 16th, 2005, 12:29 PM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
It's a wire that runs from the other side of the engine and plugs into something.
It's a fairly 'thick' small wire.
Forgive my ignorance, but if the coil has 4 small wires & one spark plug wire plugged into it then no I don't think it was plugged in there.
Nicholas
Old April 20th, 2005, 04:22 PM
mattdh's Avatar
mattdh
Matt Hurst
nicholas-did you ever find out where that wire goes?
Old April 20th, 2005, 11:45 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
My guess is that you will see an empty spade from the coil--you should really convet those all to ring connectors.
electrical
Heated seat electrical question Campbell Defender Technical Discussions 19 October 31st, 2009 09:16 AM
NAS AC wiring question or call it a random wire question bjf Defender Technical Discussions 7 May 5th, 2009 09:58 AM
Electrical for beginners paulb Defender Technical Discussions 5 October 18th, 2004 01:58 PM
