Where do i get this fitting? - Defender Source
Old June 26th, 2016, 03:05 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Need 2 pcs, 1 for the injection pump return line and 2 for the in/out of the lift pump.
From what I can find looks like it's 1/2 x 20unf thread with a barbed end on the other (using 5/16 fuel line)
Any ideas?
Old June 26th, 2016, 03:09 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Pic would help
ID:	152610   Click image for larger version
Old June 26th, 2016, 03:18 PM
Naplm00
Matthew
Do these come with the lift pump?
Old June 26th, 2016, 03:25 PM
Lowes or Home Depot might have what you are looking for.
Old June 26th, 2016, 03:40 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Not with the female flare on one end
I remember this same fitting being a pita when I did a 200tdi swap. And the place I got it from no longer exist.
------ Follow up post added June 26th, 2016 03:41 PM ------
No. But I think they come with the lines, maybe???
Old June 26th, 2016, 03:50 PM
Contractor's Avatar
Contractor
Will
1969 IIA
You should be able to get that one with the barb at West Marine.
Old June 26th, 2016, 04:47 PM
I didn't realise that was for a flare fitting.
Old June 26th, 2016, 05:13 PM
Omero's Avatar
Omero
Omar Alomar
2000 D110 CSW 6.2 LS (was TD5)
Google or search Summit
"NPT To Nipple, Straight, X in. Hose Barb to Y in. Male NPT"
Where X is the thread and Y is the hose dia.
An example...
https://m.summitracing.com/parts/sum-220184b
Sent from my SM-G920F using Tapatalk
I'm for the Russian pencil
Old June 26th, 2016, 05:50 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Interested in where the nipple you are looking for is fitted on the injection pump return line?
I am assuming you are still running the 200Tdi?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old June 26th, 2016, 06:56 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Originally Posted by roverman2010 View Post
Interested in where the nipple you are looking for is fitted on the injection pump return line? I am assuming you are still running the 200Tdi?
no this is now on a 300tsi. Different truck
I just remember the thread vexing a PITA to fine state side
Old June 26th, 2016, 07:17 PM
I changed mine to a normal union compression fitting. Steel tubing to nylon tubing. The stock fitting are custom.
http://www.red90.ca/photos/land-rove...G_1632.JPG.php
Old June 26th, 2016, 07:31 PM
Naplm00
Matthew
Return line | Fuel Lines | Land Rover Modifications | Red90's Photos! | Red90.ca
That s a good idea, I hate the heat molded nylon fuel line. I was contemplating going to clear blue urethane on my truck
Old June 26th, 2016, 08:34 PM
bossman429's Avatar
bossman429
Adrian
1988 90
So did you just cut the pipe coming from the lift pump, and then put on a comp fitting with ferrule?
Id rather not cut pipes if i can avoid it. Im sure there is a way to get this fitting.
------ Follow up post added June 26th, 2016 08:35 PM ------
An example...
But isn't it UNF thread? not npt
Old June 26th, 2016, 08:58 PM
Omero's Avatar
Omero
Omar Alomar
The pic looked tapered so assumed npt. Here's a good guide: http://blog.worldwidemetric.com/prob...ttings-thread/
Old June 26th, 2016, 09:14 PM
bossman429's Avatar
bossman429
Adrian
1988 90
The pic looked tapered so assumed npt. Here's a good guide: http://blog.worldwidemetric.com/prob...ttings-thread/ Sent from my SM-G920F using Tapatalk
Thank you for that. Yes Deff tapered so probably NPT
I'll bring it to a store tomorrow to see if I can get the thread size / type down
I just know I need to have that bevel at the end to match up to the flare which I doubt any standard male/barbed adapter is going to have.
Old June 27th, 2016, 09:35 AM
bossman429's Avatar
bossman429
Adrian
1988 90
I changed mine to a normal union compression fitting. Steel tubing to nylon tubing. The stock fitting are custom. http://www.red90.ca/photos/land-rove...G_1632.JPG.php
So this is the direction im going. Not really any other option. Do you know what size comp fitting you used? 5/16?
Old June 27th, 2016, 06:39 PM
bossman429's Avatar
bossman429
Adrian
1988 90
So I picked up some 5/16 comp fittings and that worked well on the injection pump return. I was able to cut off the old ferrule rather easily with a fine hacksaw blade.
However on the lift pump I realized the fitting I bought stuck too far out and interfered with the vacuum pump. I could get a 90 and use that but I realized there is 2.5" of tubing that sticks out and the 5/16 hose I have fit snugly around it. I know there is no barb but I figured this is low pressure anyways. Just for giggles I slid the hose on the bare tube and tightened the band clamp. Sure enough a super snug fit that I can't pull off by hand. I know this isn't as good of a fit as a barbed fitting but I don't see how this will be an issue at all. The other end of the lift pump I used the one originally fitting I had
I actually feel more confident in the connection without the ferrule, comp fitting and barb then I do on the injection pump. I just see too many points of failure on that
I may just remove it and flare the end a bit (plenty of room to do so) and do the same thing, slide the hose directly over the tube itself.
I just need a section of 1/4" hose to go from the fuel filter housing to the Input of the IP and the plumbing will be done. Well that and the fuel pick up assembly.
ID:	152685   Click image for larger version
How do these get into the USA and get sold? Grover Misc. Chit-Chat 33 April 23rd, 2012 01:15 PM
Still looking: Fitting sizes for oil cooler lines Hans Misc. Chit-Chat 16 February 8th, 2005 08:26 PM
question about rear ladder fitting my ride chirider Defender Technical Discussions 1 December 7th, 2004 11:20 AM
Fitting Tickford top to 1997 ronward Defender Technical Discussions 13 July 16th, 2004 07:17 PM
bulkhead and wiper stud fitting problem mattdh Defender Technical Discussions 3 April 2nd, 2004 09:42 AM
» Defender Registry
110
Nick&Nora
blondy
01CRF10
Add your Defender
