where do i get the 4.2 chip? - Defender Source
Old March 13th, 2006, 07:03 AM
vesparover's Avatar
vesparover
brian bertolini
Hey Everyone who has swapped to a 4.6- Where do you get the 4.2 chip? The stealership doesn't know anything about anything. I remember hearing that the 4.2 chip was inexpensive vs. the rpi chip- and that's what I'm looking for. Could you tell a difference running the 4.2 chip over the 3.9?
Brian Bertolini
Old March 13th, 2006, 04:55 PM
Only thing I have been able to find is to take one out of a 93-95 RRC
Old March 13th, 2006, 05:25 PM
artm
Arthur Maravelis
97 SW
This may be a longshot for most folks, but take one from a RRC and find a local college kid that knows about programming EPROMS. Or search online for someone offering the service. I don't know how much the RPI costs but I would bet you can get this service done for $100 or so.
I've done this back in my college days and it's a piece of cake, with the right equipment - and we're talking cheap equipment. You just place both chips in their slots and copy them.
Assuming no reprogramming is required for the security system you should be all set to go.
Old March 13th, 2006, 07:21 PM
robisonservice
John Robison
2008 Supercharged Range Rover
There is no need to change the chip. The performance difference that will result in minimal, not enough that I noticed on truck's we've done
Old March 13th, 2006, 08:40 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I have done this for my 4.6 which was a 3.9. I can't swear by the results, but it did remove the 80MPH govenor.
Old March 13th, 2006, 09:37 PM
robisonservice
John Robison
You would get that same benefit with a Range Rover or Disco ECU, neither of which have that feature
Old March 13th, 2006, 10:21 PM
yeah, who wants to go that fast in a Rover anyways
4.2 RRC LWB Chip into D90, things you should know Neil McCauley Defender Technical Discussions 13 June 25th, 2008 12:36 PM
quick help needed 4.2 oil lines Abrooks Defender Technical Discussions 8 February 10th, 2006 02:38 PM
D90 TD5 ECU Chip upgrade? Should I or not? adibitar Defender Technical Discussions 11 September 1st, 2005 01:22 AM
'94 - '95 Disco eprom chip. wh sells it? DBZ2009 Defender Technical Discussions 4 November 18th, 2004 02:33 PM
Which Chip mdmccallum Defender Technical Discussions 2 August 21st, 2004 02:19 AM
