Where did you put your ECU - Defender Source
Old December 30th, 2004, 02:48 PM
jcasteel
John Casteel
1961 Series IIa
Occasionally I'll see a note that someone moved their ECU. Perhaps it was to put in an extra gas tank or to raise the electronics further above the waterline. I have a '95 D-90 and I'm curious where you put the ECU and probably the Engine Code display. Did you move it under the hood and into a waterproof box, Pelican case or similiar?
Would placing the ECU into a sealed Pelican case cause problems?
Curious as to how you may have accomplished this move.
Thanks, John
Old December 30th, 2004, 06:07 PM
We are not sure if Mike Hippert keeps his ECU here, a bologna sandwich, or his stash of pot.
Old December 30th, 2004, 08:14 PM
I keep them all in there . The tupperware container works pretty good, it has not over heated or anything either.
Old December 30th, 2004, 08:49 PM
souza's Avatar
souza
Dave Souza
1995 Defender 90 SW #275
I raised mine off the floor of the seat box with some stacked 2x4 pieces. It gives me those few extra inches that can be sooo important. One deep hole in florida taught me that.
Old December 31st, 2004, 02:39 PM
DiscoDino's Avatar
DiscoDino
Nadim Samara
1992 Disco "Dino"
I have bolted my ECU to the top of my inner cage (Disco)...works great...had to extend the wires a couple of feet, no issues yet (6 months)
'92 Disco truggy (42"s, ZF, dual cases, ARBs, 30 splined, OMEs, Optimas, Warns, Bead-Locked)
'04 D-90 TD5 ST (33"s, tuned, caged, 1/2 top)
'84 Rangie 2 door classic (32"s, OME, ARB bar & M8000)
'04 Disco II stock
'07BMW G650X Challenge (farkled)
Old January 12th, 2005, 11:20 AM
roverboy's Avatar
roverboy
Thomas
Booger
Souza,
you said a "deep hole in Florida" taught you that lesson. Was that lesson learned in Richloam by chance? And if so...was it learned by watching Susie sink MY TRUCK??? WHat a lesson indeed. God, was that awful.
Do you remember the color of that "water"?.....Baby Sh*t green?.....Split Pea Soup?....
Ahhhh....good time$.
tom
"There is absolutely no excuse for the way I'm about to act."
Old January 12th, 2005, 11:31 AM
souza's Avatar
souza
Dave Souza
ha-ha Peacock,
Not watching you and Sus, apparently that wasn't good enough. I had to try it myself some time later. Of course it was Richloam, but it was a different hole... In fact, it was one of the holes that normally is so deep, no one tries it. But one year it was extremely dry in Richloam (a rarity) and so decided to give it a shot... mistake. I shut the truck down in the water, was pulled out and let the seat box drain. Took out the ECU, washed it off with clean water, let it dry in the sun (with the help of compressed air keyboard cleaner) and put it back in. Started right up and finished the day a little wiser and weary of the big holes
ecu
Speed Sensor and ECU Issues DJ Menasco Defender Technical Discussions 14 February 16th, 2006 08:45 PM
Interface on '94 ECU (OBD-I?) jaherring Defender Technical Discussions 10 October 11th, 2005 10:06 PM
ECU readout cbass Defender Technical Discussions 15 September 17th, 2005 10:05 PM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
97 Defender ECU nardo Defender Technical Discussions 0 November 26th, 2003 04:36 PM
