Where can I find one of these? - Defender Source
Old June 26th, 2016, 10:47 PM
RBBailey
RBBailey
1965 IIa
Ignition switch:
It is not compatible with what I found on Rovahfarm, and I cannot verify by the photos at Rovers North.
Project:
1965 IIa SWB
Old June 27th, 2016, 12:17 AM
Looks alot like this: http://www.defendersource.com/forum/...tch-36768.html
Old June 27th, 2016, 12:21 AM
Originally Posted by RBBailey View Post
Ignition switch:
Attachment 152633
Skip the switch...hotwire it!
http://www.defendersource.com/forum/...tml#post749058
Old June 27th, 2016, 12:30 AM
RBBailey
RBBailey
1965 IIa
Originally Posted by Rocky View Post
Yeah, but it isn't. I have one of those, and although the contacts are the same, it does not fit into the barrel.
Project:
1965 IIa SWB
Old June 27th, 2016, 01:07 AM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
This may be what you need?
http://www.brit-car.co.uk/product.ph...i_defender_fa_
Ryan
84 110SW County LHD
07 L322 Vogue
Old June 27th, 2016, 01:39 AM
RBBailey
RBBailey
1965 IIa
Don't know.... It appears that there are several different kinds, and I was told that they all fit, but the two I happen to have are not compatible with the same key barrel.
The only way I could tell for sure is if it looks exactly like the one I pictured.
Project:
1965 IIa SWB
Old June 27th, 2016, 01:52 AM
Puzzling.
Is it military? Or some special purpose vehicle?
Old June 27th, 2016, 02:06 AM
RBBailey
RBBailey
1965 IIa
My old one crapped out on me last spring, Ryan helped me diagnose that problem as well, and I ran with it hot-wired for a bit.
I found this barrel and switch from a seller here, picked it up and it went into the pile of stuff for then project. Bad luck means it broke this evening, and the other switch I have does not fit this barrel. The other barrel is broken, so I'm stuck.
I've managed to make the broken switch work for the purpose of just making the electrical system work, but it is a sketchy temp job that won't last the first drive.
Project:
1965 IIa SWB
Old June 27th, 2016, 02:46 AM
RBBailey
RBBailey
1965 IIa
I am pretty sure this is it. I will need to pull it out again tomorrow to look at the back side to confirm, but it has the three tabs around the edge that look to match the one I have.
What is a "STRNG CLMN" Defender?
And why is my luck so bad that I have to buy two of these in a row, it breaks the moment I get the electrical working, and then my engine won't start!? I guess I need to update my sacrifices to the dark god Lucas...
Project:
1965 IIa SWB
Anybody know where I can find one of those cool fuel door covers.? mightymo Wanted 17 February 10th, 2012 04:49 PM
Anyone know where I can find one of these? Abeer Defender Technical Discussions 3 June 1st, 2010 04:15 PM
Can't find a "mushroom" snorkle cap for my DIY system - can anyone help? solihul Defender Technical Discussions 6 April 12th, 2006 11:58 AM
Where can I find one of these??? Dfndr90 Misc. Chit-Chat 15 October 17th, 2005 01:12 AM
