Where are VIN's located? - Defender Source
Old May 15th, 2007, 03:43 PM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
I was wondering where on a 90 all the VIN's are located. Obviously behind the drivers side windscreen, but where else can I find VIN's on the truck that aren't so obvious? Thanks guys.
Old May 15th, 2007, 03:51 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
one is on the frame front rail, drivers side kick panel and on some brake boosters
Old May 15th, 2007, 04:12 PM
I also have mine on a little plaque in stamped metal on the windscreen frame in front of the steering wheel (on the inside).
Old May 15th, 2007, 04:51 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
1993 110s:
on the dash, visible through the windscreen and on the T support on the DOT decal and stamped into the RH front frame horn.
Some very early NAS 110s also had it on the brake pedal box, but only a couple
1994-1997 NAS D90s:
on the dash, visible through the windscreen and on the DOT decal on the LH kick panel on the bulkhead, and stamped on the frame as per above.
Euro Defenders had them on the pedal box
Euro Defenders also have a build sheet inside the RH front door that has build data on it.
Email:
Old May 15th, 2007, 06:43 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
my 110 had a build sheet behind the dash
vin
Engines - Located in the UK globallandrovers The Vendors Loft 1 February 28th, 2009 07:43 PM
SOLAROS - SAE 2008 - Nov 7-9 JackW Trips, Trails and Events 10 October 16th, 2008 08:30 PM
Difference in frames between Disco/110? fpkelly Defender Technical Discussions 32 January 6th, 2005 02:45 PM
White 1995 Land Rover D90 ST (located in Dallas) defender_rd For Sale - Vehicles 1 November 9th, 2004 11:27 AM
Anyone located in the Seattle Area? Joe P Defender Technical Discussions 2 November 9th, 2003 03:35 PM
