Where are the important grounds - Defender Source
Old September 26th, 2009, 11:56 AM
mightymg's Avatar
mightymg
Lane Farka
97 D90, 05 LR3, 95 RRC LWB
Where are the important grounds for the ecu and the alarm unit..
The truck has done this once before, its runnign fine, then it just shuts off like its out of gas..
What i have noticed its that when it does this I dont have a CEL when the key is in the on position, Im thinking this is a ground issue somewhere causing the communication failure betweeen the ecu and the alarm......
Thanks for the help
Lane
Also I noticed when its running fine the door beeper works correctly, as soon as it dies, the door beeper no longer works..
project whore!
95 RRC LWB-- DD
97 D90 37 " krawlers, coilovers, beadlocks, stretched
05 LR3 - Mamas/ tow rig
- Moab rally vids 2010
Old September 26th, 2009, 02:56 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Use the door beeper to find the problem. I do not think it is the fuel injection power circuits based on your description.
Ground is battery to frame to transfer case. Check and or replace this cable. Ground to firewall by heater box. Ground on back of drivers side cylinder head to firewall and fuel injection.
Things to check. Main system relay. Positive from battery to starter to maxi-fuse box to fuse panel. Starter positive leads can be hosed easily. They jumper from the battery to the maxifuse box and alternator there starter input.
Good luck
legend in my own mind
Old September 26th, 2009, 05:42 PM
mightymg's Avatar
mightymg
Lane Farka
Good luck
great thanks alot Pendy..
One thing i do remember from the last time i had this happen and I was tracing power issues, I ended up unbolting the fuze block assy under the console to check the back, and after a while of messing around ut started working again..
project whore!
95 RRC LWB-- DD
Old September 26th, 2009, 06:30 PM
pendy's Avatar
pendy
jim pendleton
89'd90
I think the main relay or a ignition switch relay gets ground from the fuse box metal suround. Check the way it fastens to the bulkhead. And check the ground to the bulkhead from the engine. Do not be afraid to add a ground wire from the engine to the bulkhead. Of a larger gauge.
May end up being the relay. It could be damaged from the resistance in its control circuit. But the resistance will have to be sorted as well.
Old September 26th, 2009, 11:36 PM
mightymg's Avatar
mightymg
Lane Farka
Great thanks alot, Ill tear the console out tommorrow to see what i can find..
project whore!
95 RRC LWB-- DD
Old June 15th, 2012, 04:15 PM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
Lane, I'm running into a similar issue and was wondering what you found with this....
In my case, the truck runs 100% fine until I shut off the heater. If I shut off the heater, about 10 seconds later the door chime sounds as if the door is open with the key on and then the engine will cut out entirely. Where should I look??
import
Re: Mallory Distributor Mpigapicha Defender Technical Discussions 8 January 13th, 2010 11:24 PM
Most important Rover owner attribute Jpayne Misc. Chit-Chat 29 September 8th, 2009 08:42 AM
Inspirational Speech... norros Misc. Chit-Chat 4 June 16th, 2005 12:51 PM
News re: Nevada Trophy - Important Doug Trips, Trails and Events 3 April 2nd, 2004 01:39 AM
