When changing out a stepper motor - Defender Source
Old May 31st, 2013, 05:21 PM
hippydrome
tenner jones
1995 d90
Hi,
Look through a bunch of threads and found out how to change out my stepper motor on my D90 1995 but how do you get the truck to recognize that the stepper motor has been changed? Do you just disconnect the battery, wait 30 sec and reset the ECU?
thanks,
HD
Old May 31st, 2013, 05:27 PM
ECU calibrates the stepper motor at every startup sequence. Reset of the ECU is as you described.
motor
Stepper Motor Cleaning - More Details Please brettm Defender Technical Discussions 13 April 26th, 2012 11:10 PM
Code 48 Stepper motor devinchi Defender Technical Discussions 8 September 8th, 2005 05:43 PM
Installing a Napa Stepper Motor p# 2-1738 Heath Defender Technical Discussions 0 January 13th, 2005 10:04 AM
Stepper motor same on RR? waveridin1959 Defender Technical Discussions 15 December 16th, 2004 10:52 AM
stepper motor erik d Defender Technical Discussions 2 February 11th, 2004 04:09 AM
