Wheels and backspacing - Defender Source
Old February 13th, 2005, 09:19 PM
Jase
Jase
pending
Although I hate to bring this up again.... I will.
Assume 15x8 wheels and 35/12.5/15 or 36/12.5/15 tires.
- 4 inches of backspacing = too little and I'm asking for the tires to redo the body?
- 5 inches of backspacing = too much and the tires will be rubbing on the frame, inner fenders, radius arms, etc.
I've run the standard 4.25 inchers your get from ARE with 35s but I was wondering if a little more would help the tire tuck inside. I ask about 4 inchers because I think that is the most you can get from MRW.
For those who have run either what are your thoughts.
Jason
Old February 13th, 2005, 10:43 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
It's 4in. That is the sweet spot. More and you hit the inner fenders, less and you hit the body. If you decide that you want something other than the norm, trekoutfitters will do any backspacing you want for $60 a wheel and 10% off if you mention this site. I am running 3in backspacing now. Would not recommend it to you.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old February 14th, 2005, 01:41 PM
Jason what tires are you thinking of? Swamper's? It kinda makes a difference as some tires are wider then the others in the same size. How close are things with what you have now? It is really hard to com-pair rover to rover as no one has the same setup (same lift, bumper tires that kinda stuff). How close are you to hitting the radius arms right now? And you know if you tuck the tires in you will be loosing some stability. Just my .02
Old February 14th, 2005, 10:26 PM
Jase
Jase
pending
Hey Mike,
I'm thinking 35/12.5 inch SSRs, for my next d90. My prior d90 with 15x8 AREs and 35 inch MTRs only rubbed on the rear fender flares. I think I'll try the SSRs and MRWs with 4 inch BS (thanks David) and adjust the suspension and flares as required. Anyone have opinions on the MRW non-beadlocks?
Anyone fit 36/13.5 Iroks on a d90 yet? If there was a 35 inch I would run these for the low weight.
Jason
ac, wheel, wheels
Walker Evans beadlock wheels!! Shane@EVS The Vendors Loft 2 February 20th, 2008 11:09 AM
15x10 4in Backspacing wheels Buckon37s For Sale - Parts 14 November 12th, 2005 02:06 PM
5 Allied beadlock wheels jdb3760 For Sale - Parts 3 September 20th, 2005 05:19 PM
Nato steel wheels with 2" backspacing Shane@EVS For Sale - Parts 5 November 30th, 2004 06:00 AM
SG 15x8 wheels w/33x12.50 MTRs WhiteD90 For Sale - Parts 2 August 7th, 2004 12:41 PM
