Wheels Adapter from 5x5.5 to 5x6.5 - Defender Source
Old August 7th, 2009, 12:40 PM
Rugbier's Avatar
Rugbier
Gustavo
Does anyone have a source for these adapters
I want to put LR wheels on my M416
The pattern on the M416 is Chevy/Ford 5 x 5.5
and ours 5 x 6.5
Wheel adapter can make one for 400.00 shipped ( ridiculous )
NO SIGNATURE
Old August 7th, 2009, 01:43 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
I used this guy for the adapters for my sankey (std trailer hub) to the DI/D90 bolt pattern.
http://www.wheeladapter.com/
I tried contacting Skulte but they were non-responsive.
If you go with Fred, call him directly. Don't waste time on the website.
Old August 7th, 2009, 02:08 PM
Originally Posted by dmarchand
I used this guy for the adapters for my sankey (std trailer hub) ...
Your Sankey did not have a Rover bolt pattern?? That is weird.
Old August 7th, 2009, 02:22 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
It is by design. It has independent suspension.
Old August 7th, 2009, 03:14 PM
Rugbier's Avatar
Rugbier
Gustavo
Dave, I spoke with him, he is the one that wants 400.00 shipped
NO SIGNATURE
Old August 7th, 2009, 03:43 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
I had great success for Skulte, and I actually had a set made for the exact same reason. Ask them if they still have the specs for the set they made for me (Greg Boshart) and they can hook you up.
Greg
Old August 7th, 2009, 04:53 PM
It is not a Sankey then.....
Old August 7th, 2009, 08:06 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Right.
Crawl back under your rock.
Old August 8th, 2009, 03:59 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I'm thinking you could probably get a set of used Rover axle ends for less than $400 and fit "new" hubs to your trailer for less than $400.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 9th, 2009, 12:04 AM
Rugbier's Avatar
Rugbier
Gustavo
That is a great thought, but I am affraid it might exceed my mechanical capabilities.
I've tried a new Trailer axle ( from like e-trailer ), but by the time I am all set and done ( granted new axle and all ) I will be at 400.00 anyways.
Thanks for the help
NO SIGNATURE
Old August 9th, 2009, 09:15 AM
Antichrist's Avatar
Antichrist
Tom Rowe
If you can rebuild the hubs on your D90, all you'd need to have someone else do is weld the axle flanges, that the stub axles bolt to, on to the axle. I'd think you could get that done pretty reasonably.
There are some other advantages to that route.
No need to faff with adapters (some need constant attention to stay tight from what I hear)
Same hubs as the D90 (2 spares if you have a failure on the D90)
Same hub bearings and seals, common parts are always good.
Just my 2 cents.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 9th, 2009, 09:53 PM
That high? I haven't looked into getting one with hubs setup for rover wheels, but without them they are almost half that. But I would still go with a new trailer axle over adapters personally. Let me know what you end up doing as I need to get myself an axle for my trailer and paln to go the custom trailer axle route.
charles
Old August 9th, 2009, 10:50 PM
I have not done this, but it is my understanding that the inside of a rover axle is capable of accepting a tube. So I think you could cut the ends off of a rover axle casing, insert the tube, plug weld it in a few spots and weld the seam.
Old August 9th, 2009, 11:00 PM
Interesting, and has the benefit of the same set of spares for sure. Will need to noodle this one over, thanks.
Old August 10th, 2009, 10:02 AM
Rugbier's Avatar
Rugbier
Gustavo
Charles and Ron,
Maybe next time as a courtesy to some of us , please "speak" english *LOL*
We'll look into options
NO SIGNATURE
Old August 10th, 2009, 02:25 PM
Antichrist's Avatar
Antichrist
Tom Rowe
This is the part I was talking about cutting off and welding to your existing axles. Depending on the diameter of your axles, you may need to sleeve one or the other.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 11th, 2009, 09:29 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
That is unfortunate. He charged me $350 in the spring. I will say that Fred turned it around fast, within 5 days to my door from payment.
When I was looking for adapters, Skulte had a big post on their site that they were not doing runs for adapters (which may have led to the communication issues). But maybe that has changed.
Either way, as mentioned. Red loctite is your friend if you do go the adapter route. Spacers and adapters have a habit of spinning the inside hub nuts right off.
Old August 13th, 2009, 07:14 AM
Antichrist's Avatar
Antichrist
Tom Rowe
I was thinking about this, and to make it even simpler, you could just weld the Rover stub axle to the axle tube, which is what Land Rover did for their 4x2 model front axles.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
wheel, wheels
Bonnet Mount Spare Adapter for Alloy Wheels Manimal Wanted 0 March 14th, 2009 12:47 AM
Disco II / Range Rover Wheels rvrnut110 For Sale - Parts 0 November 9th, 2005 01:51 AM
35" BFG AT KOs and 15x7 wheels Jase For Sale - Parts 1 August 19th, 2005 05:30 PM
5 33x12.5x 15s BFG MTs on trek outfitters steel wheels draaronr For Sale - Parts 4 June 9th, 2005 09:06 PM
MJ Lee Wheels! TwisteD90 Misc. Chit-Chat 16 February 21st, 2004 10:55 AM
