wheel wieght residue - Defender Source
Old March 1st, 2005, 10:56 PM
got new tires today and those stick on weights that were removed left some sticky residue, what would be the best stuff to get it off with? alchohol? acetone? elbow greese? I searched to no avail. thanks dudes.
Old March 1st, 2005, 11:08 PM
Who cares! Their friken wheels man! Get them muddy a few times and it'll come off when pressure washed. That or some good old WD40 hose it down wait a few mins and scrub it off.
Old March 1st, 2005, 11:31 PM
cool. I am still getting mud out from the last "outing" so I may wait till it warms up some before I venture out, its to cold to be washing this thing. I will try some WD
I just did the same drill. I used "Goof Off" product. I bought it at Home Depot. It took a lot of scrubbing.
Old March 2nd, 2005, 11:53 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
What are wheel weights!?
Old March 2nd, 2005, 11:57 AM
They balance your wheels/tires so your vehicle doesn't shake apart or you don't break your teeth while you drive down the road.
Old March 2nd, 2005, 12:50 PM
I thought they helped with keepin your Rover on the ground?
The WD-40 worked pretty well.
Old March 2nd, 2005, 12:57 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
I put 30lbs in the front & 28lbs in the rear! But there is no sticky stuff?!
Old March 2nd, 2005, 01:35 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
lighter fluid works really well too
ht, wheel
removing steering wheel Hollywood Defender Technical Discussions 25 August 15th, 2010 03:16 PM
UK land rover steering wheel mpodgorski For Sale - Parts 2 February 1st, 2006 09:56 PM
Steering Wheel Sleeve mpodgorski Defender Technical Discussions 5 December 12th, 2005 10:46 AM
Front Wheel Bearing replacement flippedrover Defender Technical Discussions 11 December 21st, 2003 11:44 PM
