Wheel stud replacement rear wheel - Defender Source
Old April 17th, 2014, 04:23 PM
richord
Richard Ordowich
1987/D90
I was installing stainless steel lug nuts on and one of the new nuts appears to have had a defect that stripped two threads on the stud about 1/2" in from the front of the stud.
I was hoping to re thread the stud but I don't think that will work.
Can I replace just one stud and how do I go about doing that?
Old April 17th, 2014, 04:24 PM
you can order new studs from RN. they are part no's. You take a 1 lb hammer and hammer the old one out, and the new one in. too easy
Mark Kellgren
KM4BOR
Old April 17th, 2014, 04:29 PM
richord
Richard Ordowich
1987/D90
Thanks for the quick reply.
What do I have to remove to knock it out, besides the wheel?
Old April 17th, 2014, 11:45 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by richord View Post
Thanks for the quick reply. What do I have to remove to knock it out, besides the wheel?
I am pretty sure you will have to remove the whole hub and take the rotor off to get the space to take off and put on the lug bolt.
ac, wheel
1985 110 Front wheel stud removal kjva Defender Technical Discussions 1 September 22nd, 2011 09:42 AM
Does one stud match up for another stud? airbornrover Defender Technical Discussions 2 May 11th, 2011 09:46 AM
ARP head stud compatibility? Hans Defender Technical Discussions 0 November 12th, 2004 10:37 PM
plastic window stud sleeves jstrong98 Wanted 4 October 22nd, 2004 10:24 PM
bulkhead and wiper stud fitting problem mattdh Defender Technical Discussions 3 April 2nd, 2004 09:42 AM
