wheel specifications from newbie - Defender Source
Old August 7th, 2011, 04:06 PM
300 TDI
ken
D90
Hello I am new to the forum and have recently purchased a 1985 defender 90 with 300 tdi motor. The 90 is in need of new wheels and tires. The 90 does have disc brakes. I was wondering if anyone could confirm some of the wheel specifications so that I may explore my options? What I do know is the bolt pattern of 5x6.5, pitch? 16x1.5 but do not know center hub bore measurement or wheel offset. It currently has steel wheels and I am thinking of alloys. I apologize for the amateur questions but would appreciate some help.
Old August 7th, 2011, 05:03 PM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
If you look at the header on this page you will see TIRES/WHEELS which gives some good info, though I think the links are dated. You might look at the Terrafirma alloys that Justin @ Lucky8 sells; http://lucky8llc.com/
Old August 7th, 2011, 06:37 PM
300 TDI
ken
D90
Thank you for the helpful hints. I'm still getting used to the forum. I will certainly check out the websitue you mentioned.
Old August 11th, 2011, 10:29 AM
djcrawfo
Derek Crawford
Series 3, 1974
Hey if you are looking for black steel rims in a 15x8 size with 3.75" backspacing, I have some that I am looking to sell. These were never used. I went with 16" instead. They are Pro Comp RockCrawler Xtreme Rims code 87-5856. I have 4 of them.
wheel
removing steering wheel Hollywood Defender Technical Discussions 25 August 15th, 2010 03:16 PM
UK land rover steering wheel mpodgorski For Sale - Parts 2 February 1st, 2006 09:56 PM
Steering Wheel Sleeve mpodgorski Defender Technical Discussions 5 December 12th, 2005 10:46 AM
Front Wheel Bearing replacement flippedrover Defender Technical Discussions 11 December 21st, 2003 11:44 PM
