Make sure you get the right one's based on whether you have rear drums or discs. If you are running steel Wolf HD wheels you will need to make sure the studs are long enough also.
I'm running 255/85-16s on my 90. I also have the RN sources wheel arch fuel tank that is a god send on weekend wheeling trips like Winter Romp (gets better every time).
Any clearance problem with 255 tires and spacers? How about 285 and spacers? Ask the last question as 255 seem to be disappearing from manufacturers sites these days. Hate to be forced into wider fatter tires but it may happen.
You have the shorter wheel studs and need the longer ones.
Following up on my year old post, I'm running the spacers and getting another set of 255/85-16 in the next two weeks when the KM3 arrive
I went with the ez accessory 1.5”
Spacers. Installed today. Question: is this how they should look? Seems
Strange with the center cap depressed inside the steelie like that. Safe?
Wheel spacers are devil's spawn. You have to re-torque them periodically or risk losing the wheels at some point.
Looking t your picture I'd be worried about the shearing stress you're putting on those lugs, but then the other fella in this thread has his Wolfs almost like that and he seems to be wheeling around happily.
I had mine on for 4 years with zero problems. I took them off because I didn't need them with the wolfs I put back on. I also have them on my porsche. No problems there either.
I’m just not seeing why these would be more prone to come off than a standard wheel. 2x as many lugs so double the possibility of a lug coming loose? Maybe. Still feels like an extreme long shot if they are torqued down to spec.
I put wheel spacers on my 89 110. I'm a little concerned about the amount of threads from the wheel stud that didn't go into the nut. It looks like it is about 3 threads left to go.
When I have the factory steel wheels (EXMOD) on it without the spacers, the nuts are flush with the end of the wheel stud.
Should I be concerned the studs are too short for the spacers?
I lost a wheel once. Luckily it was at 2AM coming home from work. No Traffic and I was going slow. It was a rear wheel so the only damage was it scraped up my disc and when the wheel came off it knocked off some of the wheel arch rivets. Luckily I wasn't going 65 on the freeway in traffic. I'll never use them again. The funny thing was when I pulled them all off it was only the one wheel that had any lug nuts loose. I know I torqued them all down on installation as well.
Related Threads
Defender Source Forum
1M posts
24K members
Since 2003
