wheel spacers anyone better than another ? - Defender Source
Old April 25th, 2012, 08:24 AM
kjva
Ken Jackson
1985 110 Wagon
Looking for a set of 30mm wheel spacers for a 1985 110. Looking on ebay.uk there is a wide range of prices is anyone better or worse than the other ?. Looks like one place does 4 for around 100UKP while Terrafirma is 150UKP for what looks the same.
Old April 25th, 2012, 08:36 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Do a search on this forum. Many guys have bought them from a U.S. based ebayer.
Old April 25th, 2012, 09:01 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Pretty sure these are the ones I got.
http://www.ezaccessory.com/Wheel_Ada...5650-5650c.htm
They used to be on eBay all the time but it looks like they are available direct on their website. Hard to beat for $100 a pair
Old April 25th, 2012, 09:06 AM
tjfslaughter
thomas
Burbon
thats the ones.
Old April 25th, 2012, 09:22 AM
wow, nice price. I'm tempted to buy a pair for the front to get rid of the razzafrazzin rubbin'
Old April 25th, 2012, 09:28 AM
lots of info on them here if you search ezaccessories or ez accessories (or if you had searched "wheel spacers" it probably would have shown up on the second page). Jeff has basically the same truck as you. I run them on the fronts only.
Old April 25th, 2012, 09:30 AM
kjva
Ken Jackson
1985 110 Wagon
Thanks for the info will get a set, the rubbing irritates me as well. I usually check ebay.uk for any parts to give me some idea of prices
Old April 25th, 2012, 09:03 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
If you are getting non-hub centric spacers make sure that you bolt them down in a good pattern or you could get some vibration. If you choose not to use loctight make sure you re-tighten them after a few hundred miles.
Land Rover 110
Old April 25th, 2012, 09:48 PM
Talk to Jeff before you do. I don't know what brand they were but he got a bad case of the wobbles when he put his on.
Originally Posted by pendy
I'm here for the D's
Old April 26th, 2012, 09:07 AM
kjva
Ken Jackson
1985 110 Wagon
Could you expand a little on the non-hub centric vs centric spacers. After new shocks, springs, bushes all round plus a new steering box the last thing I need is wobble / vibration.
Old April 26th, 2012, 09:08 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I figured out my wobbles were caused by haste of installation and lack of cleaning
Old April 26th, 2012, 11:19 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I just got in a pair of 1" spacers from BORA/Motorsport-Tech ones: http://www.motorsport-tech.com/speci...ck/landrover_s
Saw them on the Pirate4x4 board and thought they looked good for the price plus I wanted 1" and not 1.5" or 30mm. I am going in a different direction though and might not need them it turns out.
Old April 26th, 2012, 11:30 AM
I believe the differences between non-hub and hub-centric spacers are:
1. A center hole specifically designed to rest around the hub ring normally machined into the wheel hub.
2. A lip around the exterior of the center hole which mimics the hub ring on the wheel hub.
The idea is that certain vehicles have alloy wheels designed to interface with a hub ring on the wheel hub, forcing the alloy wheel to be centered on the hub.
I'm not sure that defenders have these hub ring lips.
ac, wheel, wheel spacer
Safarigard 1" aluminum wheel spacers dannykkim Defender Technical Discussions 1 March 7th, 2005 04:29 PM
Wheel spacers artm Defender Technical Discussions 4 December 13th, 2004 10:44 AM
wheel spacers krisp For Sale - Parts 15 November 30th, 2004 11:03 AM
Wheel spacers Dfndr90 Defender Technical Discussions 1 September 9th, 2004 12:22 AM
Wheel Spacers? Joe P Misc. Chit-Chat 5 April 9th, 2004 12:24 PM
