Wheel Shake - Defender Source
Old March 24th, 2016, 12:50 PM
bjf's Avatar
bjf
barry f
94 ST #395
Wheel Shake
Trying to figure this out.
Truck shakes at like 55. Thought it was tire balancing.
1. Switched tires to another set of wheels and had them rebalanced. Shake still there
2. Switched springs, shocks, added new tires and wheels. Still shakes there.
Build has extremely low miles on it so I doubt it has a bushing issue.
Any thoughts?
Old March 24th, 2016, 01:01 PM
Check tie rod ends, drag link end, swivel ball preload, wheel bearings....easiest test is to stand next to the tire, shake it from the top. You don't *need* to jack it up, but if you do put your hands at 12 & 6 to shake/test (make sure to have jackstands on there so you don't smash your hand if your jack fails).
If you feel anything "bump" or "clunk" like it's loose or hear it, then it's likely wheel bearing or swivel preload. If you do the shake from top as-is method, put some force on it...if it feels tight move on to check other stuff, but if there's any clunk or looseness investigate further.
My guess would be wheel bearings...but that's a total shot in the dark obviously. Bushings/etc can be suspect, especially the panhard pushing, genuine stuff does fail. Steering box too if there's any play, but rather unlikely unless it's high miles or high wear & tear.
Take Tylenol for any headaches. Midol for any cramps .
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
You could remove 1 driveshaft at a time, and see if it goes away. Obviously you need to Engage the CDL to drive around like that. Sounds like it could be a u-joint.
Old March 24th, 2016, 01:13 PM
d90boy's Avatar
d90boy
keith humphreys
aka: Mr Fancy Pants
just sell me the truck and dont worry. =)
Old March 24th, 2016, 01:15 PM
bjf's Avatar
bjf
barry f
94 ST #395
Being its in steering wheel I would assume it is front wheels and not a driveshaft. Will start checking crap.
Old March 24th, 2016, 01:18 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
This isn't the death wobble is it? Steering wheel violently shakes?
1994 Defender 90
2006 LR3 SE
1996 Discovery I (sold)
1991 Range Rover Classic (sold)
1995 Range Rover Classic (sold)
2006 LR3 SE (sold)
Old March 24th, 2016, 01:22 PM
bjf's Avatar
bjf
barry f
94 ST #395
It's a bit of that
Old March 24th, 2016, 01:30 PM
cruisermatt
Matt M
Rover-less Scum, 1990 TLC
Check every part between your transfer case output flanges and wheels for play.
Need more information here, what size tires, any lift? If so, any kind of caster correction ? What do your pinion angles look like? How does the truck actually drive, does it track straight? How does it do as far as "return-to-center" after turns? When is the last time you had an alignment?
Old March 24th, 2016, 01:33 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Originally Posted by bjf View Post
It's a bit of that
That shit is scary on interstate. If it happens on smooth surface meaning you don't have to hit a bump to get the shaking I bet wheel bearing. Most people get this symptom and the first thing they want to do is run out and buy a steering dampener, it's not that.
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old March 24th, 2016, 01:44 PM
lrna04's Avatar
lrna04
Michael
1994 D90
If its a new build then I would suggest re-positioning the steering box to the frame. The location of the box to the frame allows quite a bit of slop. Its a good idea to re-position this after new suspension has settled or for example you add a winch/bumper.
1 loosen large the bolts holding the steering box to frame.
2 go for a slow drive around the block with this loose and allow it to find its happy place.
3 torques up the bolts
4 on axle stands, rotate the steering wheel lock to lock and return to exact center. I used masking tape on the dash and steering wheel to find exact center.
5 adjust the steering box to remove play then take off the jack stands.
6 adjust the draglink to straghten the tires.
If you still have issues, check swivel ball preload as mentioned in previous post.
what's your toe setting?
does it happen going dead straight or when you are making gradual sweeping rh or lh turns?
Old March 24th, 2016, 01:48 PM
death wobble is almost always panhard rod bushings or bolts are loose. See torque settings, they are pretty high.
Also torque it down with wheels on the ground not with truck on a jack, otherwise you can tear the bushings when you lower the truck.
Old March 24th, 2016, 02:09 PM
bjf's Avatar
bjf
barry f
94 ST #395
Will check. Thanks
truck has 265/75/16 tires
stock ride height.
aligned two days ago.
Old March 24th, 2016, 04:00 PM
Will check. Thanks
stock ride height.
Had same issue with my lwb w/same size tires. Swapped panhard with another from my spares pile. Problem solved.
Old March 24th, 2016, 04:07 PM
All suspension bolts must be re-torqued after use if this was recently assembled. Next suspect is swivel pre-load or lack thereof.
Old March 24th, 2016, 04:08 PM
1. Panhard bushings
2. swivel preload
3. loose wheel bearing
4. Shot steering damper
5. Worn out steering box
6. Worn out ball joint[s]
My money is you stop going down the list at 1. Bushings are an age thing not a miles thing IME.
Old March 24th, 2016, 04:21 PM
bjf's Avatar
bjf
barry f
94 ST #395
Just changed springs, and front shocks but it did it before so I assume unrelated.
Will start check stuff when I'm home.
Old March 24th, 2016, 05:18 PM
Shakes all the time or just under acceleration/Cruising/coasting?
Old March 24th, 2016, 05:23 PM
bjf's Avatar
bjf
barry f
94 ST #395
Shakes at around 55mph. I'm ruling out bushings. Talked to owner and its been happening since it was built. No clue why he didn't address it before. Going to assume something is loose.
Old March 24th, 2016, 05:33 PM
cruisermatt
Matt M
The fact that it's only at one speed pretty much (I've seen exceptions) rules out anything driveshaft or differential.
My money is on a wheel bearing.
Geared Restorations - Matt
wheel
Wheel arches (spats) Steering wheel dash parts tomaco1 For Sale - Parts 6 April 10th, 2012 12:50 AM
NAS 110 ownership and shake down through Yosemite... IPSC_GUY Misc. Chit-Chat 20 April 1st, 2010 04:57 AM
For Sale: Defender Steering wheel adaptor for Mountney wheel SeattleRRC For Sale - Parts 2 February 11th, 2009 04:46 PM
Wheel Adapter - NOT steering wheel nikojo Defender Technical Discussions 0 June 9th, 2008 12:49 AM
Rausch Creek Shake and Bake rvrsrvc Trips, Trails and Events 6 July 23rd, 2007 05:27 PM
