wheel nuts - Defender Source
Old December 30th, 2013, 10:27 PM
CaptMidnite
Daniel Choi
94 NAS Defender 90 ST
wheel nuts
From personal experience and reading previous threads, I have accepted the fact that the chrome capped D90 factory wheel nuts are crappy and after abuse from the elements and air wrench jockeys at the tire shop, they will get out of shape and size.
Some suggest using the steel wheel nuts for alloy wheels from the RRC.
Will these work: http://www.roverparts.com/Parts/NRC7415.cfm
The person I talked to at AB seemed to suggest the chrome capped ones are the only ones for the factory alloys.
Or, just replace with new chrome capped ones and take good care of them?
Any other solutions?
Old December 30th, 2013, 10:37 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
You can also just remove the silly chrome caps.
Rent my
Old December 30th, 2013, 10:44 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
The person at AB has obviously never heard of the Range Rover Classic.
Old December 30th, 2013, 10:47 PM
Talk to Eric xtn 231 at AB. He's brn2whl here.
He knows his shiat.
Old January 1st, 2014, 01:47 PM
CaptMidnite
Daniel Choi
That YouTube video technique worked like a charm. Couldn't track down an M16 1.5 bolt though so I worked it off a wheel stud (with tire removed). Also put another bolt inside the socket because otherwise the spacer bolt punches through the skin of the chrome cap
Old January 2nd, 2014, 04:08 PM
RobTheGob's Avatar
RobTheGob
Rob
1963 IIa 88 & 1995 NAS D-90 SW
I replaced all 23 of mine with these (All Makes part #NRC7415):
http://www.lrdirect.com/NRC7415-Whee...s/?sfi=NRC7415
They worked great - I'm glad I replaced them before I had a flat on a trail. I had at least one stubborn lug nut on four of the five wheels.
Old January 2nd, 2014, 05:21 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
The steel nuts are nice but you could also carry a 28-29mm socket too. Usually works with beaten up caps.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old January 2nd, 2014, 08:58 PM
CaptMidnite
Daniel Choi
I like the pop-out the caps method because junkyards will sell you beat-up Discovery I nuts for about .50 each.
Old January 3rd, 2014, 04:36 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Put some stainless steel nuts and be done with it.
- Charles Eames
Old November 19th, 2015, 01:36 AM
Promark420's Avatar
Promark420
Bryan
97 NAS D90 SW #0221
Reviving this after noticing all but two of my crappy chrome-capped lugs don't fit my 1 1/16" tire iron. Triple checking that these lugs fit a NAS D90 with freestyle alloy wheels. LUG NUT STEEL WHEELS SERIES III,DEFENDER,RANGE ROVER CLASSIC, DISCOVERY I, RNS066, RRD500010 - Rovers North - Classic Land Rover Parts
Old November 19th, 2015, 05:38 AM
Bottom line you need to replace the capped lugnuts as they age.
Old November 19th, 2015, 06:41 AM
ezzzzzzz
Mark Garrenton
LRdirect is about as cheap as you'll find new these days. I did find this source at about $49 (no VAT) for a set of 20 but I don't know what shipping might be, NRC7415 WHEEL NUT -. For under a $100 you get a solid nuts that accept a 27mm 6 point socket. It's a no-brainer.
Old November 20th, 2015, 01:28 AM
cowboy
steven
'84 110 & '90 127 LHD 2-carb V8's
I used the larger sized "Gator Grip" to remove the ones that my RRC's tire tool wouldn't fit:
Sears.com
wheel
steel wheel lug nuts thewap Defender Technical Discussions 12 August 24th, 2006 08:43 AM
Steel Wheel Lug Nuts woldd90 Wanted 1 November 19th, 2005 07:44 PM
Brand New Set of 5 Locking Wheel Nuts kpracer For Sale - Parts 2 December 23rd, 2004 07:29 AM
Brand New Locking Wheel Nuts kpracer For Sale - Parts 2 July 26th, 2004 12:53 PM
