wheel nut question - Defender Source
Old August 14th, 2013, 03:40 PM
CaptMidnite
Daniel Choi
94 NAS Defender 90 ST
wheel nut question
Previous owner of my 94 ST had mismatching wheel nuts on the wheels, so I went to a u-pull-it and found some Discovery I wheel nuts for about 75 cents each. I recall D1/D90 wheel nuts are compatible but they seem to be oddly off. The Discovery nuts fit a 1 1/8" wrench perfectly, while the nuts from my Defender fit loosely on a 1 1/8" wrench. On the other hand, the D90 nuts fit the factory lug wrench while the D1 nuts seem a tad too big. I thought of pounding the slightly too big D1 nuts into the factory wrench socket to make them fit. Or should I just upgrade completely to aftermarket lug nuts. Suggestions?
Old August 14th, 2013, 03:45 PM
The threads/stud are the same but factory and aftermarket lug nuts may require different tools to remove them.
If it was me I would find 23 of the same dimension lug nuts, either factory or aftermarket.
Old August 14th, 2013, 03:50 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Well, there's that. Then there's also the fact that the capped Rover capped lug nuts suck ass and deform, thereby requiring a larger socket.
Old August 14th, 2013, 03:57 PM
I can't remember - are the lug nuts 28 mm? First you want to have the correct sized wrench. They should be Metric, not SAE.
They are probably all the same lug nuts, but because they're capped (they suck) one has deformed more than the other. If you pound the too big one into a socket, you'll have to pound it back out which will just leave a huge dimple in the middle of your nuts. And they still won't be fixed.
Get some RRC steel (non-capped) lug nuts like these:
http://www.defendersource.com/forum/...ad.php?t=45870
and leave them as-is, or like I did:
http://www.defendersource.com/forum/...ad.php?t=46414
and you'll be better off. I've almost been left stranded with the capped lug nuts when they wouldn't come off of one wheel, so I'll never put those on ever again.
Old August 14th, 2013, 04:26 PM
CaptMidnite
Daniel Choi
thanks . . .
The capped nuts were probably deformed in some way. Visually, the nuts from the D1 look exactly the same as the Defender ones . . . just a hair off in sizing.
Old August 14th, 2013, 06:00 PM
Just get a breaker bar and a six point 1 1/8in socket and it works fine for swelled nuts.
Old August 14th, 2013, 06:38 PM
GaryBaxter's Avatar
GaryBaxter
Gary Baxter
That's what she said.
Old August 14th, 2013, 07:52 PM
CaptMidnite
Daniel Choi
thanks for the tips
Thanks for the input everyone. I was basically looking for a solution that would give me one wheel nut size/one tire wrench size for the whole vehicle at reasonable cost. Either I'll have to carry two sets of tire wrenches or keep hunting for decent M16 x 1.5 nuts.
Old August 14th, 2013, 08:23 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
The solid RRC nuts alleviate this issue.
-Jeff
Haha, yours are on the way! Should be there tomorrow!!
Old August 14th, 2013, 08:40 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Agreed, no physical difference besides the fact that someone used an impact to break tension, or used the incorrect sized wrench.
Old August 14th, 2013, 08:44 PM
1 1/8th works on normal ones too. They all suck other than, as Briggs says, the all steel RRC ones, but you should not use those on steel spares.
Old August 14th, 2013, 10:02 PM
No longer 'Ron good?'
-Jeff
Ron good sure. I did it forever. Not safe for general use.
wheel
Wheel Question K9Phil Defender Technical Discussions 9 February 13th, 2013 03:13 PM
Steering Wheel Question cthoekenga Defender Technical Discussions 5 February 7th, 2011 11:21 AM
Steering Wheel Nut Torque ronward Defender Technical Discussions 2 October 8th, 2006 11:34 AM
